Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
