Question about Bosch Dishwashers
BOSCH EXXCEL SMS50E02GB/07 DISHWASHER DOESNT WORK, PANEL SAys e 15 connect water supply
  • 641 Answers
SOURCE: bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Posted on Sep 09, 2007
natengel
  • 19 Answers
SOURCE: Bosch Exxcel MAXX dishwasher not taking any water
yes u got water on the bottom and there is a switch there first take the water from the bootom
Posted on Dec 30, 2007
SOURCE: Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Posted on Aug 13, 2008
  • 409 Answers
SOURCE: Bosch Exxcel Dishwasher operating instructions
hi there,
can you supply the complete model # for me and also an e-mail address and i will e-mail you the pdf file.
thanks
Posted on Sep 25, 2008
  • 409 Answers
SOURCE: Bosch Exxcel Dishwasher - manual please?
hi there,
no problem. the model # is usually located on the inside rim of the cabinet. open the door and locate the sticker itself. i will also need your e-mail address, so i can e-mail you the pdf file.
Posted on Nov 05, 2008
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Hallo I have bosch dishwacher and red light check water. allready water pipe is fine.could you help me pls?? thanks
If your water supply is fine and filters not blocked the problem could be the water supply solenoid inside the machine has stopped working.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Check Water Supply display lights up
It sounds like there is a filter or screen on the water inlet that is partially clogged, check for that.
May 17, 2017 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dec 29, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Nov 06, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosh exxcel dishwasher heater problem
Sep 09, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
111 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
