Question about Logitech Cordless Mouse
My cursor is too sensitive and flickers all over the screen. How can I fix this?
  • 63 Answers
If your mouse cursor is too sensitive, you can adjust it in control panel.
1. Click Start 2. Click Control Panel 3. Open Mouse 4. Adjust the sensitivity and click OK
Posted on Apr 11, 2011
Cursor has mind of it's own - goes manic
You should go to help section under mouse, cursor and adjust the sensitivity.
Aug 30, 2013 | HP Compaq Presario V2000 Notebook
How to stop cursor from floating while typing
The erratic movement of the mouse cursor might be due to the high sensitivity of the touchpad.
Try these steps may be your problem due to the high sensitivity of the touchpad
-Go to the Control Panel (large icon view) > Mouse > Device Settings > Settings
-Under the Synaptics Settings, go to Pointing > Sensitivity > Palmcheck and set the palm sensitivity near the maximum settings and test.
If this didn't help you then simply get the the reginout to optimize your laptop . hopefully you will be able to fix this annoying issue
Jun 23, 2013 | Computers & Internet
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Hp mini 110 screen fliclers if cursor moved to top of screen
Video drivers ? Reinstall them ? Does same thing happens on external monitor ?
Nov 20, 2012 | HP Mini 110-1037NR Netbook
Fix flickering screen
Flickering screen is often caused by a defective cable. Check all the cables attached to your monitor.
If you think all your cables are in good condition, the problem is probably with the environment. Monitors are sensitive to magnetic fields. Change the position where you have your laptop.
The problem might also be caused due to refresh rate not properly being set. In this case your screen will flicker when you open images or videos. Just adjust the refresh rate that will be available in graphic properties.
If the above solutions don't work, you probably will have to change your display.
Sep 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ62-225NR...
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
Cursor arbitrarly jumps to wherever it may be sitting on the screen. makes typing very difficult
This is an issue with many laptop users because the touchpad is so sensitive that while typing the cursor can be moved when the hand comes into slight contact with the touchpad. You can go into the properties of the touchpad and try reducing the sensitivity and see if that helps or disable the touchpad in the device manager and use a usb mouse.
Oct 03, 2009 | Dell F3534 Touchpad
Toshiba keyboard problem with window vista enterprise
I have seen this before.
Either you are touching the touchpad with your palms as you type, or the touchpad is set to be very sensitive. Either way, you should reduce the sensitivity of the touchpad. Go into the control panel, and go into the mouse properties. On the hardware tab, you should be able to find advanced properties and the sensitivity adjustment. Move the slider to the left to reduce sensitivity. If you stroke the pad very very gently with your finger, the cursor should not move at all. adjust sensitivity until this happens.
Reduce the sensitivity until the cursor stops jumping. This will fix it. :)
Aug 21, 2009 | Computers & Internet
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Logitech Cordless Mouse Logo
152 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
