Question about Mintek Portable DVD/CD Player w
Where can I buy a mains cable and headphones for my Mitone Portable dvd player model no: MITDVD- 1
5 Suggested Answers
SOURCE: DVP615 A/V cable
I don't know if the person who posted this problem checks back for the answer.. but I just called Zenith.. who's actually run by LG now I suppose.. Anyways, the customer service rep verified that the a/v cable is just the standard RCA a/v cable that you can pick up anywhere, so it should be easily replaceable if you don't find the original..
Posted on Dec 05, 2007
SOURCE: Mintek Portable DVD Play Model MDP-1070
ebay
Posted on Feb 14, 2008
  • 303 Answers
SOURCE: Where can I find a mains charger for Phillips portable dvd player
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for PHILIPS PORTABLE DVD PLAYER
Posted on Mar 04, 2009
z89s
  • 225 Answers
SOURCE: I have a trutech LMD5702RT portable duel screen
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
Posted on Jan 09, 2010
Portable lcd dvd player does not have any sound
Usually if there are headphones connected, the speakers are turned off.
Apr 10, 2014 | Coby Tfdvd7751 7 Dual Screen Portable Dvd...
We have a picture but no audio, when connecting Zenith DVB211 DVD) player to Vizio CABLE TV...
If you are using the original cable, is it fully seated? Is the volume on the player up? Or is it all the way down.
Does the playback set recognize the audio source? A work around if using the original cable- use a 1/8 inch mini double ended stereo cable like some computer speakers use and plug into the headphone jack over to the 1/8 inch stereo "Audio In" connector on the set.
Jan 24, 2012 | Zenith DVP615 Portable DVD Player
Set-up for portable DVD player by Craig cmd420
Hello
[1] Insert the batteries into the Craig DVD player. Depending on the model you are using, the batteries are either rechargeable lithium-ion batteries or store-purchased AA batteries.
[2] Plug the 3.5mm cable into the headphone jack on the side of the Craig DVD player
[3] Insert the opposite end of the cable into the "Aux" connection on the car stereo. Without this audio-input option, you will be unable to hook the Craig DVD player up to your vehicle.
[4] Power on the Craig DVD player and insert the desired DVD. The video will load onto the display screen while the audio is played through the car's stereo system.
[3]
Oct 18, 2011 | Craig 731398407019 Portable DVD Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Not enough sound from the headphones.
Every time you add another set of headphones it will cut the power sent to each headphone down as the power is shared between all the headphones being used. If you need it louder simply use less headphones as the unit does not have enough power to run all 3 at the volume you desire.
Aug 08, 2009 | RCA DRC6331 Portable DVD Player
Wire
any electronic store like best buy or fry's should have it even curcuit city should have it
audio video Y cable with 1/4 headphone adapter
or even online
heres one
http://www.digital4cheap.com/Shop/Control/Product/fp/SFV/31341/vpid/2243774/vpcsid/0/rid/124946
heaphone jack with audio and video RCA plugs at the end
good luck
Jun 17, 2008 | GPX PDL805 Portable DVD Player
Portable DVDs
Salutations jwatts325,
There are specific models that have auxillary monitors that will be powered from the main unit. Unfortunately if its not configured with an auxiliary unit there isn't a way to chain two portable units together.
Sorry I couldn't be of more help.
Jon
Go Ahead. Use Us.
May 21, 2008 | Televison & Video
MITONE MP3 player software files are formatted
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware:
1. Disable USB cable, turn off player.
2. Holding down "M" connect the USB cable.
3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
6. Turn off the player through the safe extraction devices.
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
Mintek Portable DVD/CD Player w Logo
81 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
