Question about Toshiba e-Studio 350 Copier
I have toshiba e352. when printing on it i got 4036 error in the log tab. my question is: what this error code means?
  • 132 Answers
Hi
Error 4036 on the copier is. User authentication error. The user who intended to print a document is not registered as a user.
The way to repair the error is to reister the user on the machine.
Posted on Apr 11, 2011
Toshiba Studio e352 is in error state.
Have you cleared any paper jams, removed and reinserted the toner cartridge, cycled the system power ?
Aug 22, 2017 | Toshiba Office Equipment & Supplies
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
C 41 code mean
I suppose the error code is C410.
To clear the error message, perform 08-400 => 0.
If happen again, u need to check the themistor.
Oct 03, 2013 | Toshiba Office Equipment & Supplies
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Error code 4021
4021 indicates Print job power failure
When there are running jobs, perform the job in error again after the completion of the running jobs.If the error still occurs, turn the power OFF and then back ON, and perform the job again.
Jun 23, 2012 | Toshiba E-Studio 456 Copier
8002314A
Hello leoavo87
This error code means the data on the Playstation Store may be corrupted. Try logging out and then logging back in. If this doesn't help, you'll have to contact Playstation directly to resolve the issue.
ajblaj
Nov 19, 2010 | Video Game Consoles & Games
My printer lexmark e352 shows an error code 84 replace fotoconductor unit. How to reset this error code
The above error code refers to :-
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Lexmark E352dn Laser Printer
Fax option gd1200
the GD1200 can be used in the e352 / e280 / e230 / e350
Apr 03, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e-Studio 350 Copier Logo
913 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
