Question about Garmin nuvi 205W GPS Receiver
No detailed maps found that support routing.need to download software on to micro sd card for garmin nuvi 205
    President:
  • 1,514 Answers
The solution to the "No detailed maps that support routing" problem can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
To set up a map on the micro SD card you can follow the instructions on http://www.fixya.com/support/r5628920-update_garmin_satnav_maps Don't download directly to the micro SD card as it won't be recognised by your satnav. Download to the computer and install from the computer to the card as described at the above link.
Posted on Apr 11, 2011
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
No detailed maps found that support routing. The nuvi cannot be used without them. No maps can be brought up? turn on and I get the message above
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 14, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin says no detailed maps found that support routing? It will not go away and the reset I tried didn't work. ???
Did you try a Hard Reset, or just push the button on the bottom of your Garmin Nuvi 205?
I hope that helps.
Jan 30, 2010 | Garmin nuvi 205 GPS Receiver
No detailed maps found that support routing on my
This is a common problem. Your map unlock code has either been corrupted or is missing. Please see this link for more info on this problem:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Aug 24, 2009 | Garmin nuvi 205 GPS Receiver
New Sd CArd-8gb. Trouble completing upload maps.
I have uploaded maps to a SD micro card from my Nuvi 250 to my Nuvi 205 but the 205 wont give me the option to select maps from the SD Card.
Can some one please help.
Thanks in advance.
Jul 08, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
NO DETAILED MAPS FOUND
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
May 10, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
