Question about Bosch Washing Machines
Some of my clothing is getting small holes appear ie t shirts and some times jeans i don't over load today it has ripped a towel
  • 2,510 Answers
There could be several reasons:-
Incorrect use of chlorine bleach
Unfastened zips, buckles hooks or fasteners
Ribs, tears and broken threads
Degradation of material
Hard objects left in pockets
Some sharp foreign object caught in holes in the drum and ripping clothing - feel all around the inside of the drum for sharp objects.
Posted on Apr 11, 2011
  • Taradb Feb 08, 2012
    My machine is doing the same thing. Tech support had our repair guy replace the drum and bearing on a 3 month old machine. Yesterday.. same problem. Tech support is now having our repair man replace door gasket and front half of tub. They are aware of the problem and a memo is coming out to replace the rear half... The fact that they are now having us replace the front half makes me wonder if they just don't have a solution and if it is a design flaw.
    FYI.. yesterday one of my son's shirts was actually still wedged between the drum and the gasket. This was the first time that I was actually able to see where the clothing was getting stuck.
Stop Kenmore 700 series top loader from ripping small holes in towels?
Look for damaged rotor, possibly small dents with sharp edges or cracked unit that catches the clothes.
Feb 17, 2015 | Kenmore Washing Machines
How can I remove 24"
for most towel bar and bath accessories there is a very small screw or allan bolt, located on the underside of the post, which holds the post to the mounting hardware and you can simply unscrew it to remove the post and then remove the hardware w/a screwdriver (usually phillips) saying that...i just looked up the installation instructions for moen towel bars and it says very specifically that the posts snap or click into place on the mounting hardware...it also refers to a square hole located on the underside of the post. perhaps we are meant to put a small flat head screw driver in there to release the "clip" and post. here are the installation instructions: http://www.faucetdirect.com/mediabase/specifications/yb2218_5624sp.pdf
hope this helps:)
Jul 29, 2011 | Moen 24 In. Towel Bar...
My Adora front load washer is shredding my clothes. It doesn't happen every load but some of my shirts are getting ripped/torn. There doesn't appear to be anything sharp in the tub. Anyone know what is...
Had that problem for a while with mine, It seemed to do it once in a while....then we stopped putting our jeans/pants in with the rest of the colors. and it stopped happening. we was our pants seperatly with them zipped and buttoned now, have not had anymore ripped or torn clothes since.
Hope it helps.
May 13, 2010 | GE Washing Machines
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer either doesn't dry or burns my clothes
ck air flow out vent at back try drying load with vent hose disconnected ..if drys ok ck vent from inside to outside for restrictions
Dec 21, 2008 | Dryers
Tiny Holes in My Cotton Shirts
If you have granite counter tops then they are ausing it - There is either a small chip in an area where you lean across a lot or your edges are too sharp ( usually with a bevel this happens). I had the same problem for 8 years! Recently put masking tape all the around the edges of my counter tops to test this. No new holes. Just paid a guy to come and smooth down the edges all the way around - expensive but the savings in therapy bills will be worth it- I had been driving myself crazy tring to figure it out and slowly eliminated all other suggestions. I read where one women just started wearing an apron and that solved it for her but I spend too much time in the kitchen for that.
Try the tape - it is a cheap (though not attractive) test. I left it on for a month to be sure. Make sure to check bathroom counters, laundry room ,etc.
Ann
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Nov 08, 2007 | Washing Machines
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
330 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
