Question about Neff Dishwashers
Neff dishwasher water pressure not high - Neff Dishwashers
  • 2,510 Answers
Remove the bottom strainers plates and make sure that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Apr 11, 2011
5 Suggested Answers
BingoDabbers
  • 102 Answers
SOURCE: Water pressure in dishwasher too high
Try regulating the pressure via the supply tap on your wall. Alternatively buy lots of miniature bungee straps to hold down the items.
Posted on Oct 06, 2007
  • 1314 Answers
SOURCE: Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Posted on Feb 18, 2008
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
  • 1891 Answers
SOURCE: neff dishwasher water not been pumped out
ck drain for kink in hose . and if connected to disposal ck the hose at that point . must be clear. ck for bone/glass / toothpick/ ect / m m
Posted on Dec 17, 2009
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
Neff dishwasher constantly pumping
Possibility is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 04, 2013 | Neff Dishwashers
The machine is on but the water has stopped coming through to it please advise
If the inlet tap under the kitchen is ok and the water pressure is ok, then it is possible the water inlet valve in the dishwasher is faulty. you can locate the part on this diagram.
Aug 03, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Our Neff dishwasher does not fill with water.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 12, 2011 | Neff Dishwashers
I have a Neff Dishwasher S5443X2 and the dishwasher tablets are not dissolving. The tablet door is open when the machine finishes but most of the tablet remains. We tried using detergent but still the same...
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jun 27, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
No water going into machine
may be the electric valve on the incoming water line is broken or too low water pressure, may be also the program knob is faulty or the cpu does not give signal for the electric valve to open when u select the program
Jan 08, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Mar 09, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
richie46
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
