Question about NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router
I have a netgear 3300 router which connects to my PS 3 with no problem, but I can't get the PS3 to read the 2TB of media that I have connected to the router. All other laptops can read all media from the same router.
r0cks0ul
  • 3 Answers
SOURCE: Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Posted on Mar 17, 2007
bee2busy
  • 51 Answers
SOURCE: Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Posted on Feb 26, 2008
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
quakefiend
  • 15 Answers
SOURCE: ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Posted on Jul 21, 2008
YourTech
  • 63 Answers
SOURCE: how to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Posted on Oct 06, 2008
I cant get my netgear N300 wireless router to work with Netflix on Playstation 3. says ethernet not found on tv
ethernet not found means there is no connection via the cable to the router.
have you configured the wireless settings on the ps3?
Feb 27, 2011 | NetGear Computers & Internet
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Ps3 problem
- Physically connect the PS 3 to the Belkin router on one of the LAN connection
- Check the connection of the PS3 (if not connecting through)
- Contact your PS 3 manufacturer to gather the ports of the PS 3 and open it on the port forwarding of your router configuration page.
Note: you'll needing to allow the ports of your PS3 and IP address to the Belkin router.
Mar 07, 2009 | Belkin F5D7330 802.11g/b Wireless Adapter
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Laptop with broadband internet and router. how to connect PS3?
This is what you have to do:
First, disconnected the router form the PS3.
Connect the router to the incoming cable and setup from the laptop using the setup wizard.
Once you have connected to the IPS then disconnect the router, connected the PS3, then the router.
You should be able to connect to the Internet.
If you have any question related to this router, please consult your router hand book, or repost your question or e-mail me at frcs68@hotmail.com,
since this router has several feature, need to configure in order to secured the net work.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Setting up wireless connection
Make sure your Netgear router is working correctly and is allowing the PS3 access to it. I suggest visiting the Netgear website (www.netgear.com) and searching for the Router you have. Also try taking down any firewalls that are set up on your computer this will allow the PS3 unlimited access to the connection.
Feb 24, 2008 | Sony PlayStation® 3 (60 GB) Console
NetGear DGND3300 RANGEMAX DUAL BAND WIRELESS-N DSL GATEWAY Router Logo
24 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
