Question about Jensen Car Audio & Video
Distortion I just had a jensen power 900 amp and to rockford 10 subs hooked up in my truck at moibleone audio. there is distortion at low volume and gets better when i turn the volume up but still has distortion. I took it back and they said it was my factory radio having no rca's but my other truck with factory radio did not do that. is this true?
    Genius:
  • 1,139 Answers
One word, No.
Distortion comes from the audio signal being clipped by one of your elements in the system.
What I would do first is measure the output of the radio with an oscilloscope to see if the signal is good. If it is then I would determine if the source of the distortion is the amplifiers or the speakers.
If it is the radio have that fixed or changed, If it it not, it might be a case of the radio overdriving the Amps causing them to clip the signal peaks. check for the max signal input of the amps and make sure the system is adjusted for that.
Let me know how this turns out.
Thank you,
Shuttle83
Posted on Aug 09, 2008
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
Jl 1000.1 Bottoming out my sub at very low volume...i have a 1000d cross fire mono block that POUNDS my sub and doesnt bottom it out.. but when i hook up the JL i get to quarter volume and the sub starts...
Check The Settings On The Amp.... There Is Probably a Setting Turned All The Way To Max on it. Is There 2 Rca Cables Hooked to It ? Try Switching them around And Seeing if It Gets Better Or Un Plug one of them And See if It Gets Any Better, Would Definitely Check The Settings On The Amp First to See if That your Problem. Hope This Helps :-)
Mar 10, 2011 | Jl Audio 1000/1 Car Audio Amplifier
Jensen uv10 amp hook up
how to power on the amp on my flip out headunit
Feb 07, 2010 | Jensen Car Audio & Video
When i hook up the sub to the amp there's no sound
check the wires and the gain and volume nobs on the amp
Dec 20, 2009 | Rockford Fosgate Punch 501S Car Audio...
Problems with car system help! I have a little older model rockford bd1000 and 2 TXXAPX12RD audiopipe subs hooked up in parallel/parallel to give it 1 ohm, had it hooked up this way for a good solid 3...
Hello srolson,
When electronic components are brand new their tolerances will allow more variation. Once you get down to a 1 ohm load, the actual impedance may vary somewhat below what the amp is capable of handling. Maxxing anything out accelerates how quickly it degrades. When new the amp can deal with putting maximum power into a minimum load, but as the components heat up and wear with age, the tolerances change.
Hope this helps.
Sep 15, 2009 | Rockford Fosgate bd1000.1 Car Audio...
I have a Jensen A600HLX hooked up to Rockford 12 and it keeps getting hot and cutting off. I have it mounted on the top of the box. What is wrong?
MAKE SURE YOU HAVE A SOLID, STRONG GROUND CONNECTION BEFORE ANYTHING ELSE!!!!!
Make sure you are using the proper gauge wiring for your amp.
Is the amp set up in bridged mode? What is the impedance (Ohms) of the Rockford Fosgate 12? If the impedance of the speaker is different from the impedance for the amp in bridged mode, it WILL get hot and cut off. Also, if you overdrive the amp, the same will happen.
The amp is stable :
  • 75 watts RMS x 4 channels at 4 ohms
  • 100 watts RMS x 4 channels at 2 ohms
  • 200 watts RMS x 2 channels bridged at 4 ohms
  • 300 peak watts x 2 channels bridged at 4 ohms
  • Also, what model is the subwoofer? What are the specs? Is it single or dual voice coil?
    You can most likely mount a cooling fan on the amp and have it turn on using the remote sensor wire. If the amp still cuts out, you're overdriving it.
    Good luck and keep me informed!
    Ed the Whizman
    Aug 26, 2009 | Jensen A600HLX Car Audio Amplifier
    Not working
    maybe you should use 4 awg wire
    Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
    Sub hook ups
    There's a lot more factors involved than that.
    • Power capability of the subs
    • Type/size of the sub box
    • Allotted space in the vehicle for the sub box
    • Voice coil impedance of the subs versus the capability of the amp
    • Etc.
    Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
    Car Audio & Video Logo
    229 people viewed this question
    Top Jensen Car Audio & Video Experts
    xxxxxx xxx
    Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
