Question about Intel Desktop Board D845PT Motherboard
I am having trouble figuring out the control panel jumpers
  • Intel Master
  • 3,606 Answers
Hi, here is a few pi am having trouble figuring out the control panel - ghost2233_26.jpgolpanel connections.
Hope this will help you.
Posted on Apr 11, 2011
Testimonial: "thank you very much guru"
  • 63 Answers
Here's a link to the motherboard's user manual. The information should be in there. Hope this helps.
http://www.intel.com/support/motherboards/desktop/d845pt/sb/cs-013214.htm
On a 2000 Chevy S 10 blazer I don't have headlights or fuel pump I've narrowed it down to no ground at the relay in panel could this be the PCM or body control module I don't have any prime either
What is liter size of engine? Engine cranking do you have spark at the plugs? I'm just trying to figure if you have more than one problem? If your missing spark--fuel pump--fuel injector pulse, I'd have to check for rpm signal.
The picture is for a v6. You can see the fuse, check it, if you haven't already. You can unplug fuel pump relay, use jumper wire between terminals 3 and 5, the load side of relay. Hopefully the pump will run. If it runs with jumper but not w/o, the problem is on control side of relay. The control side needs voltage and ground. The ground is a chassis ground. voltage for control side comes from computer.
May 19, 2018 | Cars & Trucks
I'm having trouble with figureing how to set up my microphone to the computer
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Dec 12, 2012 | Dell Dimension 4600 PC Desktop
Jumper connectios
These can be a pain to find but I managed to dig through all the other info in Samsungs site and get you a direct link to a page with the jumper settings and diagrams.
http://www.samsung.com/global/business/hdd/support/userguide/Support_Setting.html
this link will demonstrate all the jumper settings you should need. If you have any trouble figuring out which ones to use, drop me a reply on this answer and I can help you sort out any additional questions you have.
Hope this helps FixYa,
Chris
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif
Jan 02, 2011 | Samsung SpinPoint V60 SV0813H 80 GB...
Spinpoint hard drive need so set up jumpers as master drive
Chris
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif close.gif
Jan 02, 2011 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17793&ProdId=385&lang=eng
You will also need Adobe reader installed to view the manual; http://www.adobe.com/products/reader/
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Cheers'
Mike
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
Worked yesterday / not working today
Someone else figured this out, but I've seen a lot of people with the same problem. Hopefully this will help you with yours. This is for WinXP and Windows Vista. It worked great for me.
*** THIS WILL VOID YOUR WARRANTY ***
1 - Disconnect the HD from USB and power supply.
2 - There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful)
3 - Now you have a metal box in your hands. Unscrew and open it.
4 - Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out.
5 - Now slide out the hard drive and controller board out gently.
6 - Unplug the controller board (power socket and IDE socket)from the Hard disk.
7 - Look at the back you will see jumper settings. (Mine was set on Cable Select.)
8 - Take the jumper out and plug it to Master ON position. now put it all back together.
Jan 25, 2009 | Maxtor Personal Storage 3200 (M1227310)...
How do I remove the control panel?
Figured it out. There are three screws under the lid. One of them is tough to get at, but if you remove the lid support and the phone rest the lid will open to 90 degrees. At that point the top just pulls away from the base unit. You may have to unsnap the small cover where the wires pass from the base to the top unit so you can pull enough slack in the wires to pull the top off the hinges. Once that's done removing the last screw is easy.
After the screws are out, prying around the edges of the panel unsnaps the remaining retainers and pops it right off.
The problem in our unit ended up being corrosion in the circuit area of the board. I cleaned up the corrosion and found one trace that was broken. I soldered a jumper around the broken trace. The broken trace was preventing 4 of the buttons from functioning. Once the jumper was in place all the buttons started working.
Back in business.
Jul 21, 2008 | Brother MFC-640CW All-In-One InkJet...
Oven control panel out
not likely a bloiwn fuse, you would have to gain acees to the control panel itself and check for incoming power supply, if your geting power to the clock the n youll need to replace clock. in the cabinet somewhere will be a wire diagram/trouble shooter. to aid you along
Apr 29, 2008 | Ovens
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all Intel Desktop Board D845PT Motherboard Questions
Intel Desktop Board D845PT Motherboard Logo
160 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
