Question about Home
Hot water temperture will not go over 33 degrees
  • 7,482 Answers
Check your water heater thermostat on you water heater tank, look for a small removable panel, remove the insulation and then you should expose the thermostat of the water heater
Readjust the thermostat to the desired temperture just be sure not to set to high to cause problems with small children.
Posted on Apr 11, 2011
What the temperture suppoe to be in the heater on a 2006 saturn ion 2 2.2L?
Check the water hoses that go to the heater core under the hood. Depending on the thermostat, your water temperature should be around 190-200 degrees.
Jan 19, 2017 | Saturn Cars & Trucks
My dyson won't turn on. In the section for the speed of fan is showing the number 33.
Hi Deborah, it's Jack at Dyson.
It's likely the '33' you see displayed on your machine is the target temperature you've selected, as the fan speed goes from 1-10.
If you've selected 33 degrees as the target, your heater will only activate if the ambient room temperature drops below 33 degrees. It would then continue to run until the temperature reaches 33 degrees once again. The intelligent thermostat is engineered to heat the room to the desired temperature, then to run as needed to maintain this temperature.
If you want the heater function to run, try increasing the target temperature degree by degree until the machine comes on. But if you want to use the fan-only function in warmer weather, turn the target temperature down to 0. The LED indicator around the on/off switch will turn blue, and the machine will run in fan-only mode to cool you down with unheated airflow.
I hope this information helps. If you'd like further help or advice from our experts, you're welcome to call the Dyson Customer Helpline directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 18, 2015 | Dyson AM04 Hot Cool Fan Heater White
How do I turn down thermostat on this water heater?
The temperture of a water heater should be approx 120 degrees. If you use a dishwasher that is the desirable tempurture to kill bacteria.
If your heater has two thermostates then make sure they are set for a 5 degree difference between them
Good Luck,
Marty
May 06, 2014 | Rinnai Water Heaters
WATER COMING OUT OF MUFFER
This happens because of the difference of temperture between the hot engine exhaust and cooler outside tempertures. Its why you see exhaust during colder outside tempertures.
Mar 20, 2013 | 1997 GMC Jimmy
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Gas shuts off befor pool or spa reaches desire temperture. Changed temperture senor, still does same thing
if using a aqualink go into calibrate you can move 4 degrees each way also you can calibrate in heater or move water temp sensor if on aqualink
Nov 07, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
It is not cooling. The temperture setting will not stay at original setting of 33 degrees
it may only need to be cleaned . ck the coil under neat and the fan that cools the coil . / clean it and if fan is not going replace it . mm
Oct 23, 2010 | Frigidaire Refrigerators
I have a Honneywell Triple Aquasatat Relay insstalled on by boiler that heats both the baseboard and hot water for my residence. The relay is set so that the low kicks on at 180 degrees and the high kicks...
The temperatures you mention are reacting in a normal manor. The drop in temperature after it first starts comes from the water being brought back to the boiler from the system. The rise in temperature comes from the residual heat in the chamber after the burner shuts off. I would not push the limits on these settings. Water from the boiler is mainly meant as an assist . You did not answer if you have another hat water heater.
May 01, 2008 | Heating & Cooling
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
