Question about Grundig GU19WDT 19 in. LCD TV
No sound on a 21in Grundig LCD TV, both using cable tv via SCART entry or DVD using AV entry. Picture OK.
  • Grundig Master
  • 19,396 Answers
Hi.
Using AV entry ensure that the red/white leads have been connected properly to TV Audio input. SCART is supposed to have built in sound. Test using a different scart.
Try disconnecting power cord for fifteen minutes, that will discharge internal component and reset the TV. Double check audio settings just in case.
If all that does not help, then the problem is likely the sound circuit inside TV. In this case the audio circuit is built-in the main board. Usually with the 19'' LCD TVs you need to replace the main board. Parts for this model are not available from third party distributors. In case the TV is defective, I suggest calling the Grundig number listed on your owners manual to arrange repair or to check part availability. To find contacts you can also use the 'International' tab on top of this page:Welcome to Grundig.
Regards.
Ginko.
Posted on Apr 11, 2011
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
Can you plug a DVD player into a Grundig P37 - 1010(B)?
Yes, connection via Scart outlet at back of TV set. Just connected mine today, works perfectly.
Feb 22, 2010 | Grundig GF70-600 TV
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
My toshiba television is receiving sound but no picture
If the tv is connected via an S-Video connector then this must be set up in the AV menu ie scart 2 = S-video
Mar 13, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
Jvc lt40ds7bj
What model of DVD player do you have? The RF cable jacks on dvd players are only for switching the RF. All players always use AV input/output or Component input/output, the later is the best.
May 12, 2008 | Televison & Video
Grundig GU19WDT 19 in. LCD TV Logo
130 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
