Hi..I hd a thinkcentre 8123 system.The problem with my system is that from yesterday it is not powered ON.But the cooler fan & cd drives are working well
    Master:
  • 341 Answers
There is a problem with the boot source. Try to fix tight the hard disk cable, boot again. If not solved, try checking the settings to see if the hard disk is connected. If connected try booting from an operating system compact disk and run a recovery of your operating system.
Posted on Apr 11, 2011
  • powercore Apr 12, 2011
    if no display in your monitor try to clean your ram card then put it back again.
Intel pentium 4 3ghz driver download
There are no drivers for CPUs.
The drivers are motherboard and device specific (the motherboard can be regarded as a device).
They will also depend on your operating system (which you should specify)
Your computer is an
IBM ThinkCentre A51 8123 isn't it ?
Go here
http://support.lenovo.com/gb/en/products/desktops-and-all-in-ones/thinkcentre-a-series-desktops/thinkcentre-a51
Enter any chosen parameters in the drop down menus at the head of the table, eg drivers for what component, operating system, to narrow your search, and look for what you need. Good luck. Report bsck if you have problems
10.December.2014
Aug 08, 2014 | IBM Computers & Internet
My old fan 12v dc1.1a but have purcase new fan 12v dc 2.4a this fan working properly but large sound are cerated.please give me suggestion.
Not all fans have the same level of noise. Even if the fans look the same, the bearings, the default RPM, and the shape of the blades (just to name a few) can all affect the sound level of a fan.
I highly recommend fans from a company called Nexus if you are looking for quiet fans.
Oct 27, 2012 | IBM ThinkCentre M51 PC Desktop
I want ibm thinkcentre 8123 drivers for windows7
Hi nancy cute47....
Sorry I could not get your drivers for you for your ThinkCenter 8123, because you did not put in which model it was... A, E, Edge, M, or S.
So what I did is got the webpage for you to finish up getting your drivers, its really easy from here.
Just fill in the boxes with the info they are asking for...and before you know it you will be downloading your FREE drivers for your ThinkCenter.
Please take time to rate me thumbs up
http://support.lenovo.com/en_US/downloads/default.page?
Sep 15, 2011 | IBM ThinkCentre A51 PC Desktop
IBM 8123 not powering on the problem is the start up fan is running continuously.
Hello Dear,
If the Startup FAN is running, means the Power is going to your motherboard and other components. SMPS seems OK. You should check the display cable and CMOS Battery.
Just try to pull out the battery and Make the machien switch ON. (Don't forget to Check the display cable is connected or not).
If it is then means your CMOS battaery is faulty one.
WIth regards
FIXYA team
Oct 09, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Not have a sound driver
You can go to the IBM website to download drivers here:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=11&familyind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
You'll have to select the correct information for your model. I was not able to find a thinkcentre 8123, but to the right, IBM also offers a "Detect my system" option in which case, you can just select that.
Apr 22, 2009 | IBM Computers & Internet
Power Supply fan is not working in ThinkCentre M50 8189 D6G
Thanks for asking ...simply check the power supply fan....remove the Power supply(SMPS) from your system 1st....then remove the fan in it....try to rotate it by hands.....if it is not rotating smothly then it needs lubrication & your power supply unit needs cleaning.....if it is working fine then check the fan power section in Power supply...
regards
Mar 14, 2009 | IBM ThinkCentre M50 PC Desktop
Fans run at full speed under normal task.
THE PROBLEM IS THAT THE CPU AND MB AND PSU IS NOT COOLING OFF ENOUGH AND CAUSING THE FAN TO RUN ON HIGH ALL THE TIME, THE PSU MAY NOT HAVE ENOUGH WATTS POWER TO RUN THE CONFIGURATION TO KEEP THE SYSTEM AND HARDWARE TO COOL.
I READ IT IN ONE OF MY PC MAGAZINE, ANOTHER PERSON UPRADED SYSTEM, ADDED SOME OTHER STUFF BUT THE MB AND POWER SUPPLY UNIT DIDNT HAVE ENOUGH WATTS TO SUPPORT BASIC REQUIREMENTS OPERATING THE SYSTEM BASIC NEEDS.
FIND SOFTWARE THAT KEEPS EYE ON HEAT ISSUES, MB, VIDEO CARD, RAM, PS, CPU, CPU COOLERS, NIC CARDS, SOUND CARDS,
ETC.
EACH PART REQUIRES SO MUCH POWER
AND HERE HOW IT BRAKE DOWN FOR EACH COMPONET
MB 20-35+ WATTS
CD ROM 20-25 WATTS
DVD 30-45 WATTS
DISK DRIVE 5 WATTS
HD 5-15 WATTS
STANDARD VIDEO VARD 5-15 WATTS
MEMORY 5 WATTS PER MB
NEW SYSTEMS WITH THE FOLLOWING STUFF IN IT FLOPPY DRIVE,CD-ROM, MB, 16MB RAM, REQUIRES A MIN. 150 WATTS OF POWER.
BUT I KNOW YOU MAY HAVE TOP OF THE LINE VIDEO CARD WITH GGR4 WITH 512MB
MEMORY, 2-8 GIG OF RAM, 23 INCH LCD MONITOR, 2 500GB HD, BLUETOOTH AND WIRELESS NETORK, AND WIFI CAPABILITIES,
NEW DUAL CORE CPU TOP LINE MOTHERBOARD, COOLED VIDEO CARD,RAM COOLER ALSO AND THIS SYSTEM POWER WATTAGE REQUIREMENTS MAYBE SOME WHERE AROUND 400-600 WATT, AND MOST OF THAT IS FOR THE SYSTEM RAM AND THE VIDEO RAM YOU ARE RUNNING
REMEMBER 5 WATTS PER 1 MEGABYTE OF
RAM
IT WILL ADD UP FAST BOY'S AND GAL'S
ROD
PS I HOPE I DIDNT BORE ANYONE,
IT MAY SAVE YOUR SYSTEM FROM BURNING UP.
Mar 14, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
IBM 6794R8G motherboard drivers
hi.. i lost my mother board cd.. i want ntwork adapter driver .. my modl nmbr is.. 8123 KDQ thinkcentre A50.. please hlp to m for network software..
Aug 22, 2008 | IBM (25P3294) Motherboard
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
