Hi, I have an AWX510E washing machine, just over a year old. The 'end' light won't turn off and allow me to start a new programme. I have tried turning off then on again and also left it turned off at the wall all of last night, but when I turned it back on again this morning the end light is still showing. what coule be causing this and how do I fix it? Don't fancy taking a whole day of annual leave to have an engineer do something I can! Thanks, Lucy
  • 3 Answers
You must consult the technician for check uping the machine withere it has a shocking wire inside
Posted on Apr 11, 2011
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Bosch logixx 7 (5 years old) Serial No WIS24140GB/07 door will not open at end of programme. start/pause, 400, rinse, spin & end lights all flashing and a bleeping sound. To open door have to switch to off...
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Aug 29, 2013 | Washing Machines
Classique dishwasher, 3 weeks old. turned it on and chose dishwashing programme. Started ok but then beeping sound and has gone to pots programme. Light jus flashes. Stopped. Cannot reset. tried turning it...
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
Sep 01, 2011 | Dishwashers
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi my washing machine wont stop running when the cycle ends - I have to pull the plub at the mains
Reason for taking a long time spinning is that it might have an uneven load. The wrong number of bath towels, for instance will mean it takes 3 or 4 tries at getting the spin right before it can spin them at the correct speed. An unbalanced load doesn't do the machine any good either.
After this wash has finished try it on something a lot lighter- say a duvet cover only with a couple of pillowcases. If that takes a long time too then the trouble is with the machine.
Looks like your "programmer" has stopped on the "spin cycle".
Could be a sensor has gone.
But everything points to the "little drive" in the programmer.
You could try "Manually Rotating The Selector Round a Few Times"
(This could free something off)
If a new "programmer" is needed, This could be more expensive than a new machine.
If the machine is under a year old it will still be under guarantee. If it is slightly over the year, but under 18 months old you still have a good case to go back to the manufacturer and get them to fix it.
Jul 03, 2009 | Hotpoint Washing Machines
I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
Nov 03, 2008 | Washing Machines
Programme not moving on
This is not something like a belt or a motor then...It's probably the Logic in the control system.
Your best bet is have a hotpoint engineer diagnose it - and fit a new control module. To buy from hotpoint they range from 70 to 90 Sterling.
In england the call out is £90 and they actually don't charge for parts if the machine less than 5 years old.
Feb 25, 2008 | Hotpoint Aquarius WF210 Front Load Washer
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Door cannot be opened
on my machine, the filter door on the bottom of the machine opens,inside there is a screw looking thing, i just give it a turn with a coin and the door pops open ,but this should tell you in your trouble shooting section of your manual, good luck
Nov 26, 2006 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
