Question about Epson Stylus Pro 4800 InkJet Printer
Epson stylus pro 4800 black ink problem
When i change the print head of this printer, The ink black was missing. When i do printing, cleaning i didn't see the black ink comes out but printer is ok.
  • Anonymous Mar 16, 2014
    black ink missing
Hello All,
I have ink for the Stylus Pro 4800/4880... I have 750 NIB Ink Cartradges!
... $25 each! OEM!
Give me a call if you would like some!
Everyone else sell's at $75 Each!
360-303-7754
or
ECAnetwork@hotmail.com
Thank you,
Have a Great Day!
Posted on Feb 11, 2009
  • 33 Answers
When you put the printhead back into the machine, did you seat the dampers correctly?
Posted on Nov 19, 2008
  • EDSON
    EDSON Jun 04, 2014
    Hello my Light light magenta was missing,and the moment that i introduced the ink ,the printer sent the message0001001E.WHAT REALLY HAPPENED?
Blocked print head
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head. You maybe lucky with this -
INKJET PRINT HEAD CLEANING FLUID
http://www.pcx.com.au/ProductDetail.aspx?ProductId=1099 http://www.amazon.co.uk/PRINTER-CLEANING-RECOVERY-FLUID-100ML/dp/B001EN9W2Y
Mar 17, 2013 | Epson Stylus Pro 4800 InkJet Printer
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Heads will not clean, done everything Epson Stylus Pro4800 Manual says it has cost me a fortune in ink and waste tank. Is there an easy way to clean heads?
Usually the simple way to clean old ink from heads is to get a container of alcohol from the drug store and either using a Q-tip or paper towel soaked - wipe the print surface of the head to remove the old ink, then run the head clean utility once after. If you cannot reach the head surface, move the print head to change ink position, unplug the printer and fold and lay the paper towel soaked in alcohol under the head and manually move the head back and forth by hand to clean it. You may need several sheets of towel and alcohol to do this. Fold the paper thick enough so it will touch the head surface to clean.
Oct 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Pro 4800 InkJet (Color printing problems)
If you do a nozzle check...do a cleaning...then do another nozzle check, you can "read" the patterns to see exactly what the problem may be. If the first nozzle check is missing half, then you do the cleaning, and the second is missing half also, check the pattern of the box to see if the missing nozzles are jumping around. If the pattern is exactly the same, you have clogs. If the pattern jumps around, you are having ink starvation issues, and may need dampers.
May 19, 2008 | Epson Stylus Pro 4800 InkJet Printer
Color problem in Epson Stylus Pro 4800
You can have problem whit the black ink. Try to print black text. And see it its real black a a green one.
If the text, print in black green it you have problem whit the black cartridge. If so change the cartridge.
Nov 15, 2007 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
277 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
