Question about JVC DR-MV7 DVD Recorder/VCR
I lost the remote control, how can rewind the hsv tape. Thanks.
  • JVC Master
  • 508 Answers
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Posted on Apr 11, 2011
Lost immoboliser key still have car key vs 1997 commador hsv
What? HSV never has a key without the commander head on it. If you have lost your 2/3 button black key it requires a new computer, try and find a VR (1994-1996) as they are much cheaper and will work fine in a vs and some vt's. There is NO way to get around that immobiliser.
Oct 28, 2013 | Wheel Boot Immobilizer and Tire Lock, 12...
My EWC1394 records programs, but when I rewind th tape, it shuts off. This happens several times before it starts to rewind the tape.
this is caused by the tape winding too tightly so when it rewinds it gets tension and thinks it is at the end of tape ,so stops.
It pays to FF and REW several times on new or other peoples tapes to have the tape acclimatised to the tension on your machine. It may also need to be serviced if it is doing it to tapes you have previously FF to the end and rewound. Older tapes stretch a little more than new tapes so are more forgiving.
{Plese rate our help ++++Thanks for using FIXYA
Sep 26, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Akai X-360 Reel to Reel won't play
The Akai X-360 will not function if the remote control or the remote dummy plug is not plugged in to the back of the machine. The remote Dummy plug has two jumpers for completing the circuit paths for the relays so that the front panel buttons will function.
Apr 17, 2009 | Audio Players & Recorders
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Kingavon remote control rc81s universal remote control
To program the Kingavon Home & Leisure 8 in 1 Remote Control RC81S:
SETUP by MANUAL SEARCH
A: Power on the device that you want to control. If it is a VCR, it must be inserterted with a tape. *(This works without a tape)*.
B: Press and hold [SET] key and press the device key (TV1 etc) at the same time.
C: The LED will be on at the moment. Then release the pressed keys.
D: Press the [POWER] key again, then release it. The remote control enters into Manual Search Mode and the LED keeps flashing.
E: Point the remote control to the device, and then press the [POWER] key. See if the device reacts or not. If it reacts, turn to step F. If not, repeat step E (press the [POWER]) every 1 Second.
F: Test other keys, if they do not work good enough, return to step A.
Feb 24, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
How to program a universal remote to an older vhs tape player
i have rc 150 remote controll.its broken.where can iget the code for this controll
Oct 21, 2007 | Toshiba CT-90157 Remote Control
JVC DR-MV7 DVD Recorder/VCR Logo
179 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
