Question about Lexmark X1195 All-In-One Printer
Is the X1195 a fax as well. If so how do i connect to phone lines?
  • jeslan Apr 11, 2011
    There is no telephone jack on the printer. Thats why I was asking as I thought it was meant to be a fax as well as printer/scanner
  • 2,574 Answers
Connect your telephone line from the wall jack connector on the Lexmark x1195 Machine to the telephone wall jack.Connect your telephone to your fax line as a normal telephone line if you don't have a handset on your Lexmark x1195.Connect the telephone line from the telephone/answering machine connection on the lexmark printer to the telephone line.
Posted on Apr 11, 2011
  • Reparatii PC - Service IT
    Your computer must be connected to a phone line.A phone connection is required for faxing to function.
    Sorry .mi mistake .you have the Lexmark x1195..right?This model device does not support and does not have fax and faxing functionality by design.
HP 2727nf fax machine Fax not working what is the problem ?
Get an analog phone to test your phone line first. Then, make sure this line is connected to LINE port on your fax machine. Use the same analog phone to connect to the EXT port to test the line again.
Use another line to call this fax number to see whether the analog phone rings. Once you know the line and connection is okay, let's reset your fax machine. See http://www.fixya.com/support/t2503076-hp_laserjet_m2727nf_mfp for the cold reset instruction.
Dec 13, 2016 | HP LaserJet 2727NFS All-In-One Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
I have no dial tone on my fax machine and i cant send or receive faxes
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Feb 12, 2010 | HP 640 Inkjet Fax Machine
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
I CAN SEND FAXES BUT NOT RECIEVE
The majority of the time, when you can send but not receive, it is a phone line issue and not the machine. Extremely rare does a machine send and not receive. So here goes the things to try and the reason. 1, Make sure the phone jack is in the "Line" jack and not the external phone jack. Believe it or not, that is the number one issue with sending and not receiving.
Next, plug a phone into the jack that the fax machine is plugged into and see if there is static.
You want to be sure in the fax \settings and advanced settings that the ECM mode is ON, and that Junk Fax ius turned OFF, Junk Fax being on will stop almost all fax from comming in.
Now, the phone line. Here is the explaination of why that can be the problem. When you send a fax, you manually make the connection to the line. When you press send a relay flips and connectes you to the phone line, therefore you have made pretty much a mechanical connection enabling the phone line, and therefore you can send.
Now, when you have an incoming fax, several conditions must me met to make the handshake and therefore connect and receive. These all have to be right in order to properly receive. The phone line voltage mist be high enough, the phone line current must be correct and there can not be much decibel loss over the line. You are making a signal connection, all those conditions must be right to receive a fax. Think of it like a TV remote with batteries that are almost dead, It still send out some signal, but it will not change channels or change the volumn,etc etc. Same principle. If the signal to the incoming fax is weak, chances are it will not connect.
Jun 13, 2009 | Office Equipment & Supplies
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Fax machine will send out but will not receive any
Sep 24, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Dedicated fax line on system phone
If you have a dedicated fax line, the fax should be connected directly to the phone line. If you have the fax line connected to one of your station ports, you may be able to see which LED lights up on your phone when the fax goes off hook. Or you can just try intercomming all extensions in order until the fax rings.
Oct 04, 2007 | AT&T Partner 18 Phone (315805B)
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
