Question about Toyota Vehicle Parts & Accessories
Toyota carina 1.8 , 1997 The alarm system still works but only visually.. No audio siren or very very weak. Can this be repaired?
3 Suggested Answers
  • 1596 Answers
SOURCE: car alarm siren won't work but still can locked and unlocked the
REPLACE SIRIEN
Posted on Jul 12, 2009
Suzman
  • 642 Answers
SOURCE: My car: 2000 BMW Z3, probably Alpine (8040?) alarm
There is no fuse for the siren and no switch to turn it off. You will have to replace the siren itself. The 2000 Z3 uses the EWS 2 system.
Posted on Aug 20, 2010
My car alarm siren will not go off
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit... Post results or additional questions
Dec 30, 2013 | AviStart 5303 2-Way Security / Remote...
The systems is working fine and no indications or warnings on the panels, but you can hear the siren at a low sound at all times. All the zones are working according to the panel and alarm monitoring...
The siren should not receive any power when in idle mode (non alarmed state). If you hear any noise, it receives some kind of low voltage. Is it powered straight from the panel or with external power supply and aux. relay? In any way - use a volt meter and measure across the sirens power terminals. If you have any voltage present check the source.
Nov 18, 2013 | Honeywell Ademco Wave 2 Wave2 Sirens For...
The alarm siren on my 1996 opel astra estate does not work . if the alarm is triggerd the hazards do flash so i beleive that the alarm is working . i tried to locate the siren but could not find it . any...
Normally the siren is located under the bonnet bolted to the fire wall or on the side of the engine on the wheel arch. I have only ever seen a siren under bonnet in a place that is not reachable from underneath the vehicle in order to prevent a would be thief from cutting the wires of the siren
Aug 09, 2013 | Vehicle Parts & Accessories
1996 camry with factory alarm but siren not working
try connect the siren positive ( normally red ) wire to ur car battery + terminal ( but make sure u cut or disconnected the other end that go into ur alarm unit ). Also check the ground wire ( normally white or white/black ) that attached to car body from ur siren..
Apr 02, 2013 | 1995 Toyota Camry
Alarm seems to work; been checked at Toyota but they say siren is broken and say it's a common fault. But everything else seems to work - you can hear the relay clicking; lights flash.
What is actually the problem, "Actually seems to work", what doesn't work.
If Toyota are on about the 9volt battery back up siren then the main siren may be working fine, but that might not be. Most cars especially Vauxhalls have a 9volt battery back up siren, so if someone tries stealing you motor and they disconnect the battery the 9volt battery will keep the siren going off.
Feb 19, 2011 | 1998 Toyota Corolla
Newly installed car alarm, LED in solid light n horn/siren blares
if you follow instruction properly than the alarm should work properly, Go over your wiring again 2-3 times make sure it make sense to you with the instructions. If it make sense than take the unit back and get another, can be faulty alarm.
Aug 26, 2009 | 2003 Toyota Corolla
Ademco 4160-12 was installed in my house in 1987.While exterior painting, the external siren wire is cut. Please help me find new siren and procedure to alarm system. This has at present only local ( siren...
any 12 volt siren will work. you my have to replace the fuse. 12volt sirens are available at radioshack, frys electronics and all over the web,
mj
Aug 06, 2009 | Ademco CIA Modem
Wirng up a bw10000 car alarm to a dj systems siren
If you're connecting at the alarm module - you want the red wire from the siren to go to the brown wire on the alarm(the one that's in a plug with 12 or so other wires), not the red (red wire is the constant power input to the alarm).
Feb 24, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
