Question about Toshiba Televison & Video
Its a Toshiba RD-XV49DT DVD/DivX/VHS Player/Recorder Combo, replaced power supply board as was blowing fuses found components have shorten out and now after replaced board, video works and i think hard drive works but not dvd drive, not opening or closing is there away of checking what sort of supply like 12volt? and there is another printed circuit board any help on this please ?
  • Toshiba Master
  • 508 Answers
The controller circuit (usually a small board connected directly to DVD drive - it is either part of the drive or a sub-assembly which is attached - and contains several ICs and small capacitors and a lot of surface-mounted components on its copper side) is probably faulty, possibly due to the original bad PSU (which you have since replaced), chances are the original faulty PSU has damaged this circuit - usually DVD drives operate around 12V DC or so. The digital controller circuit/board not only has the EEPROM/CPU etc. on it, but also has a servo supply - for the DVD (the VCR servo supply is on the motherboard). This powers the disc tray and traverse unit. The controller is not serviceable at component level; it must be replaced and in some cases, the DVD drive must also be replaced where the board is not separate to the drive. This may not be economical.
It may just be a simple case of a blown digital controller circuit - but be warned, this board is not cheap - it is part of a 'module' (the disc drive and controller together = DVD module), and you may not be able to obtain the board without a new DVD drive. Up to you what you do from here, and you might be lucky in terms of the motherboard and HDD - no damage there.
Posted on Apr 11, 2011
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
Toshiba RDXV59DTKB
You might have accidently set it to one of the special sound settings such as dolby or DTS. Bring up the main menu and look for the sound menu.
Jun 24, 2014 | Toshiba RD-XV50KF DVD/VHS Player/Recorder...
Toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
Jun 05, 2012 | Toshiba Televison & Video
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
I have a Toshiba DVD Video Recorder. How do I record from a VHS to a DVD?
For a toshiba DVD player there should be a s-video input. For a vhs you must have a vhs player that has a component/s-video output. Hook up the vhs player to the dvd recorder using an s-video cable and press play on the vhs player. Then press record on the dvd recorder.
Feb 28, 2011 | Toshiba Televison & Video
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
