Question about Kyocera FS-4000DN Laser Printer
I have an error message "Install MK" coming up on
5 Suggested Answers
  • 58 Answers
SOURCE: Kyocera FS-9100DN
Go to the menu on the printer and then scroll down to other in the menu then to service then down to maintenance and press enter. when you install the maintenace kit you have to activate developer in the service menu, then turn off the printer and then back on to run the developer unit up.
Print menumap from the printer and follow through to the service area on the display.
Any question ask me.
Posted on May 11, 2008
  • 66 Answers
SOURCE: Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Posted on Mar 21, 2009
  • 10406 Answers
SOURCE: Kyocera FS-4000DN is showing install
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Posted on Jan 19, 2011
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Fs-4000dn error 0284232
Error should be something like CALL SERVICE XXXX:XXXXXXX.
First four numbers are error code, and numbers after : is a page count of device.
Write down first four numbers and maybe i can help you.
Feb 11, 2016 | Kyocera Fs-4000dn - Printer - B/w - Duplex...
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
Call Service 7000: 0370082 Kyocera 4000dn
Toner motor lock error ,usuall ycaused by using non manufacturer toner ,you may need to get a new developer unit
Oct 14, 2013 | Kyocera FS-4000DN Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
May 27, 2010 | Kyocera Mita FS-3830N Laser Printer
Kyocera FS-4000DN Laser Printer call for service 7000:0103031
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Jan 20, 2010 | Kyocera FS-4000DN Laser Printer
Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Feb 23, 2008 | Kyocera FS-4000DN Laser Printer
Kyocera FS-4000DN Laser Printer Logo
297 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
