Question about Ovens
Nderwilt@telkowiring diagram for defy 600 slimline build in stove and oven. Grill and switch malfunctioning. Electrician needs wiring diagram
  • 3 more comments
  • Anonymous Mar 12, 2014
    oven control wiring diagram for defy 831 stove
  • Anonymous Mar 17, 2014
    the thermostat must be replaced every year why
  • Anonymous Mar 19, 2014
    its my first time to wire stove
  • Anonymous Mar 26, 2014
    defy slimline 600s
    Could somebody help me out with a drawing or layout of all the wiring connecting to that oven control knob. Thanks
    Genius:
  • 1,157 Answers
Hi dvanderwilt,
For this concern, you need to contact Defy directly since they are the only one who can provide you the wiring diagram for this specific model. For contact information please visit this link. For additional information about your machine you may also visit the link below.
Defy 600
Hope it helps.
Thank you for using FixYa.
Posted on Apr 11, 2011
How do i coonect the cooker cables to this defy 621 stove.show me with the diagram
Call an electrician. You may leave it in a dangerous condition.
Mar 31, 2018 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Looking for electric wiring for a defy slimline 600s oven
Gert, dont know if this is too late but I found it on macspares.co.za - left hand column towards the bottom under wiring diagrams
Apr 06, 2011 | Ovens
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
Re-fitting an oven door
1. Open the front door you did
2. Open the clips at the hinge housing (2) on
the right and left hand sides of the front
door by lifting them up. you did
Hold the door onboth sides and then close the door and lift
the door up to remove it. assume this is what you did. Refitting is the reversal of removal.
Jan 20, 2018 | Ovens
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
721 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
