Question about Garden
B&D jigsaw KS538SE. Have ordered new blade clamp, pin and screw. How do I remove the pin holding the blade clamp to the shaft ??
SOURCE: how to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Posted on Aug 15, 2009
SOURCE: blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Posted on Mar 13, 2010
MOTORWIZJ
  • 1340 Answers
SOURCE: I bought a BVI model
THE SAW, YOU MAY TRY A DRILL STOP BRING IT WITH YOU AND GOTO YOUR LOCAL ACE HDWRE STORE. NOT HOMEE DEPOT OR SLOWS. SUPORT THE LOCAL LITTLE GUYS. AND ASK THEM IF A RDILL STOP WILL WORK
LORIE IF'N I WAS OF HELP.. TELL ME .. THANKS JAY
REMEMBER TO BUY PRODUCTS MADE IN THE GOOD OLD USA
OH ON THE OTHER SEARCH WHAT INFO YA GOT ON THE NET.. GOOD LUCK
Posted on Sep 12, 2010
  • 14036 Answers
SOURCE: I remove the wiper arm & the outsdie lock of
IF YOU TALKING ABOUT REAR WIPER MOTOR REMOVAL YOU HAVE TO REMOVE PULL THE REAR WIPER ARM COVER BACK TO ACCESS THE WIPER ARM RETAINING NUT.DETACH THE NUT AND PULL WIPER ARM STRAIGHT OFF THE SHAFT TO REMOVE IT.
Posted on Nov 26, 2010
  • 178 Answers
SOURCE: need to remove and then
Hello Hollister, on this peticular sawzall they are using a roll pin to hold the blade holder on. If you remove the blade clamp screw, you can move the blade holder back and forth on it. You will need to get a very small punch and drive it all the way out. Look at the picture below. You will need to remove (38) and (52). It will make it much easier.
I hope this helps. If you run into trouble, I'll walk you through it, just post back.
Posted on Dec 07, 2010
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Ryobi Saws
I need directions on how to change the baldes on a reciprocating saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
I have an older B&D reciprocating saw i use and i need help with changing the blade. It has an allen screw that hold it in but even when i remove it there is still a small pin that holds the blade. I...
No, the pin holds the blade in there as a keeper device, The screw just puts the clamp on it. It was probably just stuck, If the pin is gone, driven out or out of the way, try getting it back to hook the blade on. The clamp alone won't hold it. I tried.
May 28, 2011 | Black & Decker Garden
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Do not know how to replace a blade, no instructions
The blade is clamped to the saw with two screws. Unscrew both screws slightly. Pull down on the blade to remove. Blade holder may have a pin that engages blade. You may need to giggle the blade back and forth. Install new blade inreverse order.
Sep 11, 2009 | Skil Saws
I bought a used black & decker jigsaw no. 7548 and dont know how to change the blade
several methods 1) turn collar near top of blade. spring return. same in reverse to insert. 2)Older type may have spindle screw which draws up collets to clamp blade. access to screw may be through body directly over blade shaft. thats all for now.
cheers
Aug 27, 2009 | Saws
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
