Question about Toshiba TEC B-SX4 Thermal Label Printer
I have one problem with toshiba b-sa4tm printer.in that printer the communication is not working.what is the problem.
    Champion:
  • 254 Answers
Which communication?
If its network you have to enter the IP
Posted on Aug 04, 2011
Error code c56 toshiba e-studio160
the error code means Communication error between copier and PFC.Check cable from pc to printer.
Apr 26, 2014 | Toshiba e-Studio163 Copier
Hello my Toshiba B-Sa4TM printer states paper jam but there isn't anything jammed? i don't have a clue how to calibrate the sensors any ideas??
You may have a mis alignement of the detecting cells.
The arrow on the top part of the cells should be on the round hole on the bottom part. (Green plastic mecanism)
Nov 04, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
We have a message on the window who is: SG;0121,0-68,002 TOSHIBA B-SX4T C5.7
Communication problems between the printer and the host.
Check the cable or the type of parallel interface selected in the parameters of the printer
Jun 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, well i have a toshiba e-studio 161 equipment, and i have windows 7 ultimate installed in my pc i've found drivers but them doesn't works i don't know if that is because my system it would be nice if...
Solution :
1. Cheak ur communication cable ?
2. re-install the softwear
3. when u command print by the copier what it says ??
I think it'll be the communication problem may the the cable or the softwear contol menu, u have to read the user guide 4 this printer and learn how to connect and apply this from the copier.
Jul 30, 2010 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio 207 "local device communication error
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Apr 22, 2009 | Toshiba e-Studio 232 Black and White...
I have a x5495 printer and after installing software and I try to print, I get message that no communication between printer and computer. I have checked all of the recommendations and still can get to...
The message "no communication between printer and computer". some times indicates that the cable you're using is faulty or the port selected is not the printer port you've connected your printer to.cheers.
Dec 01, 2008 | Computers & Internet
USB ports not working
check the status of usb port on device manager, install the updated usb driver
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba A215-S7416 to Lexmark 4270 all in one
Hi: I've had a lexmark printer 1410-which would find that communication with the printer error too.
I found out that you have to install just the software (CD) first.
I believe it will tell you when to hook up your printer & turn it on. I now have a brother 6 in one and I had to do the same thing. Hope it works for you.
Jan 29, 2008 | Lexmark P3150 All-In-One InkJet Printer
Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Mar 20, 2007 | Toshiba e-Studio 350 Copier
Toshiba TEC B-SX4 Thermal Label Printer Logo
116 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
