Hi I have a dell inspiron n5030 and having problems with the touchpad the pointer doesn't respond properly and goes all over the place instead of where you are tying to direct it - any suggestions? I would be very grateful for some help. Many thanks Juls
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Hi
welcome to fixya
try to download drivers for touchpad ,if you already have than update it once and update your system and antivirus once
download inspiron n5030 drivers from link below
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=dell+inspiron+n5030+drivers&rpp=12&p=1&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=related
Posted on Apr 11, 2011
  • 32,281 Answers
Try using an USB mouse to see if the pointer behaves normally.
Dell inspirion n5030 laptop
Are you using the touchpad, or a regular mouse plugged into the laptop. If you are using the touchpad on the laptop, make sure it is enabled. There is a button to the right of the F12 key to enable/disable the touchpad. If you are using an external mouse connected to the laptop, try restarting the computer by pressing the power button once (that will initiate a shut down).
Nov 23, 2013 | Computers & Internet
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Creaky dell palmrest
The screws are on the bottom of the laptop that hold the plamrest to the base. Just tighten all the screws on the bottom and see if it helps.
May 14, 2012 | Dell Inspiron N5030 Notebook PC
My Dell Inspiron M5030 Laptop Touchpad is not working at all. The settings could not load. What should I do to solve this problem?
If the settings of the touchpad doesn't load, you need to reinstall or update the touchpad driver. You can go to "Device Manager" or Dell website and download an updated driver.
Hope this helps.
Jun 09, 2011 | Dell Inspiron M5030 Laptop
Hi can you tell me where I can get XP drivers on a dell inspiron N5030
Here is a website I found containing drivers for the Dell inspiron N5030 for XP. While I haven't tried the drivers myself, it does list the specifications of the laptop, and lists each driver for each hardwar.
http://www.downloadatoz.com/driver/articles/dell-inspiron-n5030-drivers-download-for-windows-xp.html
Mar 28, 2011 | Computers & Internet
I am having a dell inspiron n5030,and my scroll is not working
Install Alps TouchPad input device driver again from dell support website
Nov 18, 2010 | Computers & Internet
Dell inspiron n5030 xp drivers
hello
i want drivers of dell inspire n5030 wireless drivers for the xp
Oct 20, 2010 | Dell Computers & Internet
Pointer erratic but not just in a corner
hi frnd.. just uninstallt the touchpad drivers from the DEVICE MANAGER and Reinstalled the driver by downloading it from "support.dell.com" ...
Take care...
Sep 29, 2009 | Dell Inspiron 2200 Notebook
Touchpad Sensitivity
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
Mar 28, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
