What does error code 2 means on proline washing machine
    New Friend:
With mine when i had the error 2 code, it was money in the filter.
Switch machine off
I had to get a baking tray and a towel, i pu tthe baking tray under the filter corner, then slowly unscrew the filter (bottom right front of machine) then let water slowy trickle into baking tray and then empty, and repeat until water stops took about 20 mins. Of course you could do it quicker if you want to flood your kitchen. :)
Then emptied the filter, then ran spin only until end. worked fine after this.
Posted on Jun 09, 2013
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does Err4 mean on proline PFL510W-U1 washing machine
    proline pfl510w u Washing Machines Questions & Answers ...
    www.fixya.com > Forum > Tags > proline pfl510w u
    Washing Machines proline pfl510w u questions and answers. ... need user manualfor proline logic on line need user manual for proline logic ... PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and ...
    Washing machine PROLINE PFL510W - Manual.com
    https://www.u-manual.com/...manual.../washing-machine-proline-pfl510...
    On this page you can get: Washing machine PROLINE PFL510W manual - is available for free download. All information such as file size, preview picture, ...
    Anyone know how to reset a Proline washing machine ...
    forums.moneysavingexpert.com/showthread.p...
    MoneySavingExpert.comApr 3, 2010 - I can't find the manual, either at home, or online. Our washing machine(PFL 1466W-U) is showing off today. We've managed to take ... Does anyone know how to stop it from running this programme, so that we can select the empty/spin cycle. We have .... Ok it's a cover not written but you know what I mean.
    Dec 16, 2015 | Washing Machines
    Washing machine LG TR9103AEP IE error what does it mean ?
    LG Top Load Washer-Understanding Error Codes - YouTube
    ? 2:17
    www.youtube.com/watch?v=ZdoJVqFKye4
    Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
    Aug 04, 2015 | LG Washing Machines
    My proline logic washing machine is displaying a err7 code and not spinning why
    follow up if the plug is connected its not the connector Error 7 is also Error code for Motor Bushes which will need replacing !
    May 04, 2012 | Washing Machines
    PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and how can I rectify it. Thanks
    Hi I also have a problem with the washing machine. It shows Err1 and it can't work. Anyone could help me?
    Jan 15, 2011 | Washing Machines
    My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
    my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
    Nov 13, 2010 | Washing Machines
    Washing Machines Logo
    1,192 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
