Hi, I've been out of the country for the last 2 months and just came back to find something wrong with my optoma 700x hd projector. It seems to be a problem with the colour display. Constant twitching on and off from black and white to colour. What could the problem be? and how can i fix it? Thanks
  • tarek_azwai Apr 11, 2011
    Yeah I just checked, the colour is twitching even when there is no video cable connected. I've disconnected a few times and turned it back on but still nothing. Is the problem serious for me to send it for repair or can I fix it myself? Thanks
  • 19,396 Answers
Hi.
The problem is often the the cable. What happens is that the projector receives colors on three different channels, and the signal is either intermittent because of a not well connected video cable, or because of an internal fault. In some case the color wheel is responsible and must be replaced.
If the problem occurs even when the projector is standalone with the blue screen, then the projector is faulty.
Try turning off and disconnecting power cord for two minutes, then test using different video cables. Also ensure that you test projector with two different sources. If that does not fix the problem, then the Optoma is defective. In that case it must be taken apart, tested and repaired. the most common internal fault giving this problem is the color wheel.
Regards.
Ginko
Posted on Apr 11, 2011
  • Ginko
    Ginko Apr 11, 2011
    Hi.
    You will likely need to replace the color wheel. That involves disassembling, but can be done by a user with electronic DIY experience. In some case the problem is not the color wheel, but depends on circuitry and components. Color wheel replacement is not too difficult. The main problems are finding a different color wheel, which is not in stock for this model, and testing to ensure that problem is color wheel. I think that the best thing to do is using the phone number listed in your Optoma user manual to get a quote on repair from a qualified service.
    See:
    SUPPORT - Optoma USA
    Optoma UK and Europe
Optoma 25hd air filter issues
Hi Cathy,
The replacement of the filter is something that needs to be done at a service center by a trained technician. If you are interested, feel free to send us a message: Projector Repair Bulb Replacement
Jan 16, 2014 | Optoma HD25-LV - HD 1080p 3D Home Theater...
Optoma hd65 has a red light. Only had it for 5 months. How do you fix?
The red indicator light usually comes on when something needs attention. Most often it has to do with the lamp timer or the filter timer. The projector keeps track of how long it's been since you've changed the bulb or cleaned the filter(s). You can reset these timers in the menu. Be sure to clean the filter before you reset the timer
May 31, 2011 | Optoma HD65 DLP Projector
Hi i have an optoma dv10 but when you put in any dvd it just comes up no disc
Seems a very common problem with this model from what i can glean on the web.. Mine failed excatly as yours nine months ago and my local electronic repair man said optoma refuse to supply him with parts.I had to rig it up to a DVD player, but now the colour wheel has gone kaput. Optoma quoting £300 to fix but won't say exactly until you send it back to them. Have decided to buy Epson and cut my losses..
Oct 06, 2010 | Optoma MovieTime DV10 Multimedia Projector
Optoma HD 65 projector, fine last night, today it wouldnt turn on with a light flashing. so i turned it off at the mains and back on again, the image was upside down (i have it hanging on my ceiling upside...
it did do a reset on the settings. The lights do indicate something if you look at the trouble shooting section in your manual. Need to know what lights are on and what is blinking this is a feedback to you. how long ago did you clean your filter. is the lamp needing to be replaced?
May 13, 2010 | Optoma HD65 DLP Projector
I bought an Optoma HD 66 projector. Worked great for about 2 and half months, today I noticed a blob of discoloration in the top left corner. What happend, can i fix this?
My optoma es526 came with a 7year colour warenty,try ringing up optoma and send your projector to them or try replacing the colour wheel.
May 06, 2010 | Office Equipment & Supplies
Pwering up and then turns off.
I have a similar issue. It might be overheating. Did you try cleaning it, using a duster? Let me know if you found a solution.
Mar 20, 2010 | Optoma HD80 Projector
Optoma EP772 lamp will not start...
try going direct connection dvd to projector .is your dvd upconverting to 1080p or just 1080i?let me know.
Aug 16, 2009 | Optoma HD70 DLP Projector
My optoma hd65 projector worked fine for 2 months, now it will not detect hdmi signal from a motorola cable box or sony dvd player. Any idea's??
hi i am running a scart lead from my sky to my projector with a s-video lead going in the back of my projector but am only getting black and white picture!! can you help
Jun 06, 2009 | Optoma HD65 DLP Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Blub out again
Hi there
Keep in mind that this is only a estimate - not true hours at all.
Does your Projector go in for a service every 3 months ?
If I were you I would take back the Projector to the dealer you purchased it from and ask them to test your Ballast ( lamp's powersupply)
Did they tell you to run in your new lamp for 12 hours straight ?
Feb 13, 2008 | Optoma H30 Multimedia Projector
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
