Question about E-Machines T2682 (000002965) PC Desktop
Offline ever since i got this computer i have been getting a pop up for a dialup box stating that i am offline, i close out of those boxes and in order to continue i have to go to tools and take the check mark off from offline, i have checked every where i can think of to stop this box from coming up but it just keeps poping up, any suggestions on how to stop the offline dial up box
  • vjracin Aug 07, 2008
    Kitkitz
    i want to thank you very much you solution seem to work, i have been going crazy on how to fix this offline problem, thanks for the help, this make two out of two for me on fixing a problem with my computer, thats to everyone and there solutions keep up the good work, thanks again
  • 80 Answers
Hello
i am assuming that you have an ip address /dns /internet settings provided by your internet service provider.
(1)
open internet explorer
click on tools
internet option
select connection tab
remove items from Dial-up and virtual private network settings
or select the option which says never dial a connection.
(2)
under connections tab
select Lan setting
check the box automatically detect settings
restart your PC
(3)
sometimes computer virus do make an internet connection...
hope this post helps
Posted on Aug 07, 2008
Cannot view offline message
When you log into Yahoo! Messenger, a little box will pop up with all the messages that were sent to you when you were offline. If you didn't have any offline messages, the box will not appear. You can choose to respond to the messages or just to close the box. However, once you do that, Yahoo! will give you a message that says the messages will automatically be deleted. There isn't an option that allows you to save them, so once the box is closed, that's pretty much the end of seeing those messages.
Jan 23, 2011 | Computers & Internet
Jan 23, 2011 | Yahoo Messenger
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
There's a small chance this might be your fix.
Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    When trying to use Outlook Express 6, I get an "Error Message " stating "an error occured while establishing the dail up network connection AOL Dailer"
    If you are using DialUp Internet Service from AOL, try establishing a connection first and the open Outlook Express.
    If you have broadband (cable/dsl) internet service from another company, then your computer is incorrectly setup. In this case, open Control Panel, Internet Options, then click on the connections tab and delete all and any listed dialup connections or simply select the "Never dial a connection" option right under the dialup connections list box.
    Also, if you are not using the AOL software, I'd recommend that you uninstall it completely to free lots of resources and speed up your computer as a result. For this, go into the Control Panel, add/remove programs and remove all AOL applications from the list.
    Feb 14, 2010 | Computers & Internet
    Can not view Yahoo offline messages
    i cant recieve offline messages from my friend in my yahoo messenger and i cant see any offline message which they sent
    Jan 22, 2010 | Yahoo Messenger
    Will not connect to Internet and cannot make connection
    when you see the message saying work offline or connect if you click connect does it come up with a dialup box or just say page cannot be displayed?
    Nov 22, 2007 | Intel PRO/Wireless 2100 MiniPCI 802.11b
    E-Machines T2682 (000002965) PC Desktop Logo
    60 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
