Question about HP DeskJet 890c InkJet Printer
What to do when the hp D1660 inkjet printer's cartridge cradle couldn't be moved ? There is not a paper jam.
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
SOURCE: print cartridge cradle stuck
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Posted on Dec 30, 2008
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Posted on Jan 13, 2009
Tro_EX
  • 19 Answers
SOURCE: Print cartridge cradle cannot move & theirs no paper jam.
Kindly check inside if there are mechanical problems. Something stuff that blocks the cartridge...dirt for example...
Posted on May 13, 2009
pineworks
  • 4041 Answers
SOURCE: screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 05, 2010
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Message on hp psc 1510 "print cartrdge cradle cannot move"
The cradle is out of mechanical sync and hitting the travel limit stops.
Aug 15, 2017 | HP PSC 1510 All-In-One InkJet Printer
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Mar 03, 2008 | HP PhotoSmart 7260 InkJet Printer
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP DeskJet 890c InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
