Question about Cell Phones
My Orange Miami phone will not switch on, it flashes the "orange" logo when charging, when removed from charge it doesn't switch on at all. This phone was only bought in September last year, so is less than a year old.
  • 4102 Answers
SOURCE: why does my orange miami
Hi it sounds like your message center number could be wrong, all you need to do is call orange and tell them the make and model of phone you have got then ask them to give you the correct message center number and ask them how to store it in your phone.
once you have this you will be able to send and receive what ever you like
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 07, 2010
SOURCE: Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Posted on Jan 10, 2009
270rexton
  • 762 Answers
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
Posted on May 12, 2009
SOURCE: My Xperia x10i is no longer charging, when pluged
try to hold the beginning of the usb-cable on your mobile side upwards.. or downwards? if it works u know your usb cable or mobile plug-in isn't working so you have to buy a new usb-cable or you have to let your mobile fixed at the store.. if nothing happend: I DON'T KNOW.. but that's what happend to my SE X10
Posted on Aug 14, 2010
  • 1010 Answers
SOURCE: can i get free unlocking
As far as I know free codes does not unlock your phone, so even if you would find a unlock code or whatever you'd have to spend some money.
I would recommend the Unlock-Zone.com site is nearly perfect and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Posted on Dec 08, 2010
How to fix an orange Miami phone
It's stuck in a boot loop you need a software reload
Jun 02, 2014 | Orange Miami - Pink unlocked Mobile Phone...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Fatal Error:
It sounds like the port not the battery. You should take it someone to repair it. They are not expensive...
Dec 15, 2011 | Dell Inspiron Mini 10 Notebook
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
raving_nanza@hotmail.com
Oct 28, 2009 | HTC P3300 Smartphone
Phone not switching on
where you plug the charger in on your phone, if you look into it you will be able to see the contacts for it to charge.
on the inner OUTER wall of it ther is 2 pins, use a needle to pull them out a little bit but be carefull not to sanp them.
just so they stick out a little bit, if you do this and the charger dont go in then dont bloody force it in otherwise ya buggered.lol
only when the orange light is on its charging, if you accour a flashing orange light do it again.
this should sort your charge problem.
however you will eventuall need to do it again.
Aug 20, 2009 | HTC P3300 Smartphone
Charging problem
try to change the battery.........
May 30, 2009 | LG Secret ? KF750 Cellular Phone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Cell Phones Logo
507 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
