Question about Toshiba 50HM66 52" Television
50 inch dlp wont restart after power outage
We had a quick power outage and the tv was on at the time. when power was restored the tv went to restart mode. it has not start restarted for two days. i have a flashing yellow light that according to the manual is in restart mode. how long does it take to restart? Ive unplugged and plugged in again and have patiently waited for something to happen. Im just about do something crazy and read a bokk or something. _fred
  • teriberto Dec 14, 2008
    but my tv sound clic, clic all the time
Did you replace the light bulb from the back of the tv set ?
check if its blown ?
if so just replace and your good to go ....
Posted on Dec 12, 2008
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
The picture of my Samsung DLP tv is getting darker. We have had several power outages over the past few days as a result of the hurricane. Do I need to make an adjustment?
Yes, or it can also be a burned fuse, you can take it to a service center and repair it yourself.
Or maybe the power outage just disconfigured the Tv try resetting it.
Aug 30, 2011 | Samsung DLP HL-P5663W 56" TV
PHILIPS 50 Inch HD DLP Projection TV the picture went out suddenly and there is not sound but a loud humming-buzzing coming from the set...any ideas on what could be wrong or if it can be fixed?
It's the optical block (color wheel) and the same thing happenned to our Philips 50" DLP. From what I've read, it's not worth the trouble & $$ to fix. Dig a hole!
Oct 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Toshiba 50HM66 52" Television Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
