Question about Kenmore 80809 Microwave Oven
Kenmore over the range microwave is dead
I turned the unit on and within seconds I heard a rather loud explosive noise. Everything had gone black and has not worked since. My husband checked the fuse box. I unplugged and replugged, but nothing has revived this gem. I purchased the unit used from a friend who changed out her appliances from black to white and have gotten 10 years use so I have no complaints, but would like to know the reason for its demise. Does this have anything to do with the magnetron? If so, what is the approximate cost to replace one? Exactly what is the function of the magnetron? I would appreciate any advice, before purchasing a new unit. I like the looks of LG and Kenmore, but see so much negative feedback for just about all brands. I don't want to purchase a lemon as I've gone through that with my refrigerator. Any suggestions will be greatly appreciated, Shirley
  • squirly Aug 11, 2008
    Thanks so much for the info. I will follow your instructions and if it fixes it will come back and leave a FixYa comment. Thanks so much, squirly
  • Kenmore Master
  • 9,098 Answers
Since there was a loud pop, then the fuse blew, I would say the high voltage rectifier diode and fuse have blown.
If so, a do-it-yourselfer can fix this for about $25.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There may be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here is a link you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(The magnetron is a vacuum tube based device that outputs the microwave energy waves)
Posted on Aug 10, 2008
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
My microwave makes a loud humming noise when it is turned on. What do I need to replace?
Good possibility your start capacitor is leaking. When it goes completely it will blow fuse or circuit breaker causing a dead condition. You can get and replace this yourself but be careful to discharge the capacitor with a set of test leads across the terminals. This part can hold dangerous voltage! Of course, unplug the unit first. The magnetron is expensive if you can even get one. For the cost of most new units, this may be too much unless it’s a over the stove model.
Feb 04, 2018 | Kenmore 69682 Microwave Oven
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
I have an over the range microwave, and it suddenly stopped heating. Also, makes a loud noise when you turn it on.
It sounds like the High Voltage diode (1) is shorted but it could be the magnetron (2) or the HV capacitor (3). - 1 side shorted to ground. A dead short will blow the fuse and kill the unit.
Sep 11, 2009 | Microwave Ovens
Lost heat on microwave ,everything else works fine simple fix?
Inexpensive fix yes, but quite dangerous as you have to either replace the High voltage Diode or the magnetron depending on what has gone. Most often it is the Diode as that is fed a few thousand volts and anomolies such as a surge in current cause it to blow(popping sound) You can also check the fuses and if lucky it is just a fuse, but a fuse very seldomly just blows as it points to an underlying fault such as magnetron , capacitor or Diode. Have a service man attend to it unless you know what you are doing as you are dealing with lethal voltages and current even after the microwave has been switched off.
Aug 01, 2009 | Kenmore Microwave Ovens
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No Power at all after loud short buzzing sound
sounds Like an electrical fault in the Micro, Sorry but this is broken.... If this is within warranty (do check as some warrantys are for 3 yrs or more) get the manufacturer to replace/repair it for free. you could get it serviced, but it is probably cheaper to buy a new one.
Aug 24, 2007 | Sharp R-1460 Microwave Oven
Kenmore 62622 (model) -microwave-loud noise -no heating
dis-assemble waveguide and clean thoroughly. try again. if no-go then failed magnetron. get new unit.
Jun 08, 2007 | Kenmore 62622 Microwave Oven
Kenmore 80809 Microwave Oven Logo
521 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
