Question about Samsung HP-R4262 42 in. Plasma Television
What resoloution should i use when using it as a pc monitor i have it connected with hdmi cable
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Hello there,
This model TV support max 1024 x 768 resolutions , VGA (HD-15) pc interface.
Posted on Apr 11, 2011
I am not sure how to connect my gifted LG 295 LM Monator to my PC
so it has power ?
is p.c ?vga display output ?
https://en.wikipedia.org/wiki/VGA_connector
is monitor vga input ?
or is p.c only hdmi output ?
https://en.wikipedia.org/wiki/HDMI
if vga on both you need a vga cable
if hdmi on both you need a hdmi cable
if pc is VGA and the monitor is hdmi then an adapter is needed
if p.c is hmdi and monitor is vga then an adapter is needed
suggest figure out video cable standards and then decide on what you need
as shop will need to know what standards are used VGA or HDMI ?
Jan 18, 2017 | LG Computers & Internet
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
When my blu ray player is on no matter what I do screen still says resolution mismatch, how do I fix it? Pushing play and stop does not help
Unplug HDMI cable. Connect Bluray to tv using composite video cable. You should then be able to access the bluray players menu to set the hdmi output to a setting that is compatible with your tv (see your TV manual for compatible resoloutions. Once set disconnect the composite video cable and reconnect the HDMI cable.
Aug 02, 2014 | Televison & Video
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
CONNECTION WITH THE TELEVISION SHARP
are you saying that you cant see the desktop icons on your tv? maybe you need to adjust the resoloution on the computer screen to fit the the resoloution/size on your tv. try lowering the resoloution of your computer
Feb 28, 2013 | Lenovo ThinkPad T400 - Intel Centrino 2...
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
Connect my pc using VGA port into Video three... can not get picture to show .. is there something else I need to do
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitor Desktop. You need either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output, Adjust the resoloution the resoloution "Slider", it is best to start with 800x600 32bit color. or even lower. and once working OK, THEN increase to max resolution. Once all connected up. It should all work great. Now the process is, turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop. Now you have screen 1 & screens 2. If using "Cloned" then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one Big desktop. Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control panel, this all then can make it all alot easier to do, so I would suggest that this method be used. But if you get stuck, then the "By Hand" method is the only way. There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Feb 07, 2010 | Sanyo DP37647 37 in. LCD TV
Samsung T220HD - can't access HDMI input sources
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
May 09, 2009 | Samsung T220HD LCD Monitor
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
Picture flashes
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Oct 18, 2007 | Sony Playstation 3 (PS3) Console
Samsung HP-R4262 42 in. Plasma Television Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
