Question about Dryers
My Kelvinator ED55 dryer emits a high whistle while operating. When I open the door it keeps operating. the red 'lock' light remains on. Any ideas?
  • 213 Answers
SOURCE: ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Posted on Nov 26, 2007
  • 36 Answers
SOURCE: LG Electric Front Load Dryer door whistles!
under warrenty call serv tech they ussally know whats wrong from svc bullitans
Posted on Dec 28, 2007
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
iwillfixforu
  • 619 Answers
SOURCE: Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
Posted on May 16, 2010
Testimonial: "Thank you. I will try that"
heatman101
  • 43501 Answers
SOURCE: My dryer(LEW0050PQ2) power button appears to
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Kelvinator auto Sensing Dryer ED55 trips the fuse in the fusebox as soon as the dryer is turned on. All other appliances switched off therefore not overload.
check that it is not a fuse but a circuit breaker ( earth leakage breaker) that protects not only against overload but against faulty machines
if there is moisture, bad insulation , incorrect installation or anything that could cause an electric shock that unit will shut down the power supply
call an electrician to find the fault
Oct 18, 2016 | Dryers
Solid red light after installation of battery and setup of crank. Door locks twice when hit lock button
The bolt might not be lined up correctly. It needs to operate freely. Make sure bolt operates smoothly with key and turn button .
Jul 15, 2014 | Weiser Lock Locks & Locksmithing
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
Battery Keeps dying, Car thinks doors are still open when closed .
Please check all door close sensors for each door.
Apr 15, 2013 | 2005 Lexus ES330
How to remove a door switch from a fisher and paykel ED55 dryer
see the video and use the common sense. God bless you
Sep 28, 2012 | Fisher and Paykel Dryers
Can't open the door
If the door remains locked and will not open, there is a manual release you can use to open the door. The following link explains how:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
Sometimes using the manual release will correct a momentary door jam problem and return the washer to normal operation.
If the door continues to lock and not open, you may also try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes problems are experienced as a result of a momentary glitch in the operation program. Resetting the CCU can often correct most minor problems.
If you require further assistance, please post back and let me know. I hope this helps you.
Jun 09, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Dec 22, 2007 | LG DLE2532W Electric Dryer
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
