Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Regrigerator stopped, now freezer too.
We have a Jenn-Air JSD2789GES. The other day the refriferator side stopped cooling. The freezer and ice maker were still working. Now the ice maker and freezer have stopped too and it makes a buzzing noise about every 5 minutes.
  • Anonymous Aug 09, 2008
    I have a JSD2488GE and my freezer is working fine so far but the refer has stop or running warm, pulled the unit out from wall cleaned coil and checked the compressor which is running hot also the coil fan is cycling fine, turned the thermostat or cooling controler to it's lowest setting no change..... do I have a sticking switch or contact stuck open ?
  • hoop105 Feb 08, 2009
    I have a JDS2789GES and am having problems with mine also. Came home today and both the refrigerator and freezer are not cooling. We purchased this in June of 2002 and have had problem with it about a year ago, but just the refrigerator. Now it is both freezer and fridge. Happened today, a Saturday, so will have to wait until Monday to get a repairman here. Hopefully someone has a solution to the problem.
    We also have a problem with the ice maker motor running all the time. Sounds like it is trying to dump the ice, but can't. Keeps making ice though.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Posted on Oct 03, 2008
I was just surfing around for some troubleshooting solutions because I am having the same problem. We unplugged the fridge for a day a couple weeks ago when we were having the same problem and that seemed to get it cooling again. Now it is cooling but we have it turned all the way down to lowest setting and it is not cool enough.
Posted on Aug 28, 2008
I also have the jsd2789ges model and the refrigerator is no longer cooling but the freezer seems to be working fine. Any advice? There was a bit of frost on the freezer back wall so I used a hair dryer to get rid of it and am now waiting to see if that helps.
Posted on Aug 25, 2008
It happened to me also. My refregerator side stopped cooling. They freezer seems ok. Ice maker does not seem to make ice.
Why are we 3 people having the same issue in Aug 08. Is it the age?
Posted on Aug 23, 2008
Jenn-air refrigerator not freezing or making ice
Before you go crazy just defrost the unit over night and then turn it back on. Possible e that the evaporator froze up due to the open door..Let it stabilize for at least a day and then check to see if all is copacetic.
Sep 14, 2017 | Jenn-Air Refrigerators
Unit is a Jenn-air JRSD209T. Two problems. When water runs to fill the ice maker it runs down into the ice shoot leaving you with a cup of water with your ice. Second problem. Witnessed a red glow...
For your first problem i need a bit of a clarification. Is what your saying,when you dispense ice through the door some water also comes out of the dispenser??
For the glow that is perfectly normal,what your seeing is the glow of the defrost heater melting off the biult up frost. If it did not come on and melt the frost the refrig would not be cooling.The term"FROST FREE" is a bit misleading. Their is automatic defrost refrigerators such as the one you have, and the manul defrost that you need to defrost manually every month.
Gene
Aug 12, 2011 | Jenn-Air JSD2789GES Side by Side...
Water not draining to pan when defrosts draining into freezer causing ice build up at bottom of freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Jenn-Air JSD2789GES Side by Side...
Water freezing on floor of freezer and leaking on to floor in front of freezer?
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Feb 18, 2011 | Jenn-Air JSD2789GES Side by Side...
My Jenn-Air JSD2695kes. The refrigerator side is not cooling.
You most likely have a defrost cycle problem. Either a bad defrost heater, timer or thermostat. Jenn Air has put an Adaptive Defrost circut in the top of the Refrigerator section. You can find troubleshooting directions at ACMEHowTo.com
Jun 03, 2010 | Jenn-Air JSD2695KES Side by Side...
Ice maker not working, just stopped all of the sudden
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
aragag
Jan 15, 2010 | Jenn-Air JSD2789GES Side by Side...
Refrigerator side doesn't keep things cold, just cool, despite having it on the coldest setting and the cold vent open between the freezer. The freezer is working fine.
Look on the back wall of the freezer for a ice buildup. If there is ice you have a defrost problem. The defrost timer is in the fresh food section inside the control panel.The defrost heater and defrost thermostat are behind the freezer back panel inside the freezer.
Also check the freezer fan. If there is no ice buildup in the freezer the freezer fan motor could be bad.
Nov 21, 2009 | Jenn-Air JSD2789GES Side by Side...
The refrigerator makes a noise about every 4 minutes, like a it is trying to start something i don't think it is the ice maker
sounds like ice maker . when noise is happening open freezer and listen to the ice maker and see .. it could be ice stuck in the ice maker and needs to be freed up......
Aug 12, 2009 | Jenn-Air JSD2789GES Side by Side...
I have a Jenn Air JSD2789GES side by side refrigerator and The water won't work to the ice maker or the water in the door?
Check if the water is on.
check if the water filter connected correctly or the bypass.If the filter is new and the appliance is new you should press the water handle or button till the water comes as the selenoid are open during you push.
Jun 30, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
495 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
