Question about Vacuums
I have a blacspur safe bbes100 the lock has broken and the handle spins round
    Brigadier General:
  • 3,917 Answers
Hi
There are only three reasons that a safe lock won't open -
1. Incorrect dialing sequence,
2. Incorrect combination, or
3. Mechanical problems, which could include damage or simply service issues.
If YOU can't get it open, then you will need to have a safe technician check it out and/or open it for you.
You can check your yellow pages under "safes & vaults" for a company in your area. It is not recommended calling locksmiths as they generally do not have the training, knowledge or tools to work on your safe without causing unnecessary damage. As parts are not available, this shouldn't be an option.
Also check their customer service address:-
Customer Services Department
Blackspur Tools
Hamble Distribution Ltd
Spring Industrial Estate
Lanesfield Drive
Ettingshall
Wolverhampton
WV4 6TZ
and their phone # is 01902 353636
http://www.wholesalesupplies4u.co.uk/m/214/view-wholesaler-details/blackspur-tools.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 11, 2011
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
Even if the flat belt is broken and the v belt loose shouldn't the shafts or something be spinning when I flip it over and turn it on? Nothing is spinning on mine
There is a tensioner pulley that drops when you drop the handle down. It squeezes the belt against the roller making it spin. This part often breaks as well. Replace the flat belt, and check to make sure the v belts edges aren't rounded. If they are and the edges are not crisp replace that belt as well. DO NOT put the v belt under the tensioner pulley. It will break should you do so. I'll include a link to the correct part # for that flat belt.
http://www.vacuummedic.com/product.php?id=6
Aug 18, 2012 | Hoover U5780-900 Windtunnel Cyclonic...
Brushes wont go round on my dyson?
This is most likely a problem with the belt. Try spinning the brushroll around. If it spins freely, you have a broken belt. Those are pretty easy to repair and you can get the parts at evacuumstore.com
Nov 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction and rollers not spinning
Hopefully this will help. On the back of the vacuum at the bottom the is a U shaped tube. Depending on what model you have it will either be a thumb release or a quarter turn screw head release. Remove that and check for a plug. Two things can cause the roller to not turn, 1) Broken belt or 2) Shut off switch. On the head, to the right there is a round large knob with a pointer, it must point to the lines (or carpet). If in the other position it is shut off for bare floors. Remember that it automaticly shuts off when the handle is in the upright position.
Nov 02, 2010 | Dyson Vacuums
Handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Jan 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Upright lock broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559827
Generic problem for all Vacuums
Upright lock broken
Posted by diamond8990 on Apr 30, 2008
Upright lock broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and the model # it sounds to me that you have a broken handle release if that is what you are referring to as “Upright Lock Broken” – the handle release lever keeps the hand staying up and in the upright position. So include @ least the brand name and or the model # and I can try to further assist you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
