Question about Futaba Toys
I have a Futaba R603ff 2.4ghz Fasst 3 Ch Receiver that stopped working efficiently. The throttle servo cut out working and the steering hardly moved, then, when the throttle started working again, the speed was way slower than it should be and the steering was still not responding properly. When I try the same radio settings on another truck of similar design, the steering and throttle response are perfect. Is there a way to reset the receiver ?
HOEEEE
  • 7 Answers
SOURCE: Technics SA GX130D receiver amp keeps cutting out
This is either due to heating problems or You may need a new power unit inside.
Try having the amp out in the room so it has plenty of air, make sure nothing is blocking those vents
Regards
Posted on Jan 05, 2008
SOURCE: Logitech keyboard not working
try doing a system restore to when it was working
Posted on Dec 25, 2008
yooperbud
  • 8637 Answers
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Posted on Jan 16, 2009
  • 421 Answers
SOURCE: can't get new transmitter working on remote control car?
Double check that the crystals are in the correct parts of the radio gear. You should have one marked with T and that goes in the trasnmitter and one marked with an R and that goes in the receiver. Make sure that the batteries are fresh and that the aerial wire of the receiver isn't damaged.
Posted on Jan 17, 2010
  • 421 Answers
SOURCE: hobbie tower wed page say that can work with 2 ch
You onky need one servo for steering as the esc does the power for you. You should get the basic Tamiya esc from tower. Something like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGMR6&P=7
Setup instructions will be in the manual and with the ESC.
How do I figure out if servo is bad or the receiver is bad? steering and throttle not moving...yes the battery is new
You can run straight power to the servo.. just make sure it's the correct or better lower power.. switch the wire from +/- will reverse the servo.
Sep 10, 2015 | Toys
Out of control revo 3.3
your receiver battery is low or check to make sure servo is working..if its working then its a low battery
Jul 16, 2013 | Traxxas Rc Revo Nitro Monster Truck
Regarding the BLS452: 1 What is the maximum (electrically driven) rotation? 2 What are the pulse widths for the maximum rotation? 3 What is the current consumption on 6V? 4 Is it digital, & if...
Some of the information you're requesting is at the following link.
http://www.helipross.com/futaba-bls452-brushless-ep-car-high-torque-servo.html
The current consumption will be dependant on the loading of the servo.
Digital Servos give and quicker resoponse to your input and provide a higher torque in a shorter period of time. Full explanation st the following link.
http://www.futaba-rc.com/servos/digitalservos.pdf
Jun 23, 2011 | Futaba Bls452 Brushless Ep Car Hi-torque...
Steering servo makes hard rt turn without turning steering wheel. batteries are fully charged and all connections appear secure. can temporarily eliminate prob by turning transmitter off/on.
2 possible problems:
transmitter-The variable resistor inside your transmitter is stuck fully on. Take apart the transmitter - look for the part under the wheel. It should have a 3 wire variable resistor under there - check for broken wires shorting to the other side or simply broken solder joints.
2nd possible answer is the car has a shorted output drivers on the motor controller board.
hard to fix without a schematic.
the guaranteed seo services provider
Apr 13, 2010 | Futaba 3pm-fs Pro 3-ch Synthesized...
My nitro rc traxxas truck is not turning what do i do?
Check servo saver to make sure it has not loosened up. If the servo is not trying to turn at all check the connection at the receiver. If it is okay, you can always switch the steering and throttle servos at the receiver to rule out the possibility of a faulty servo. They can fail if they get too wet or get hit hard enough.
Dec 27, 2009 | Traxxas T Maxx 3.3 Monster Truck
Steering on a remote controled car not working
Check the servo saver to make sure it is not loose. You should be able to hear the servo move or try to move. If it does not make any noise when you turn the wheel on the controller open the receiver box and make sure that the steering servo has not come unplugged from the receiver. If these things check out the servo could possibly be bad. They can get damaged if they get wet or are hit hard enough.
Dec 06, 2009 | Traxxas E-Maxx 4WD Monster Truck RTR
Can't get new transmitter working on remote control car?
your receiver is old 89-92 and will not work properly with your newer transmitter. you need a R122JE receiver.
Sep 09, 2009 | Futaba Two Servo Trays For Standard Rc...
I have a Futaba T9CP transmitter sending to a FP-129DP receiver and on to 6 digital servo's 4 hitec and 2 futaba and they all appear to be delayed in there response to the transmitter movement and they...
have you got any expo dialled into the settings, this will delay or rather soften the response to your servos, the glitching you are getting may be due to you be close to the reciever and swamping the sinal hence the glitching, see if it goes when you walk away from the transmitter
Apr 22, 2008 | Radio Shack (15-2147) Remote Control
Toys Logo
54 people viewed this question
Top Futaba Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Futaba Toy Expert? Answer questions, earn points and help others
