MY SOUND PLAYBACK, SOUND RECORDING, MIDI MUSIC PLAYBACK, VOICE PLAYBACK AND VOICE RECORDING HAS ALL BEEN DEFAULTED
    Master:
  • 341 Answers
Back up your files to a seperate disk and restore your computer to a previous state when with a date of when the sound used to work. If it doesnt solve the problem, look for sound drivers of your sound device and reinstall it. Here is how to restore the machine: Requirements: Your computer must be on, booted up and running,Pad and pencil to make notes about restore date. Method:Click on Start, select All Programs, select Accessories, select System Tools, click on System Restore. The next screen is a Welcome to System Restore. Here you will make the choice of the task that you want to perform. Select "Restore my computer to and earlier time". Good idea to click on help at the upper right hand corner. Print and save these instructions as you will need the information in the next few minutes.The next screen that pops up is of a chart showing choices of restore point dates. Select your desired restore point date and click on "next".The next screen is a confirmation to make sure that this is what you want to do. Follow the instructions.Click "next" and your computer will start restoring itself. When complete your computer will be working the way it was a few days ago. If your have problems there is plenty of help screens if you need to undo it
Posted on Apr 11, 2011
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
My roland gx 700 is communicating with the computer but cant playback
In the computer control panel under "sounds and devices" check that the 700 is the default device for "voices" for recording and playback and also under the the "audio" tab.
Mar 26, 2011 | Music
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Recording do not sync up
1rst- Maybe you choose the incorrect metronome. On analog audio record use your default audio card metronome and on MIDI audio record, use MIDI metronome!
2nd- Check your memory video card & remember your computer speed is as fast as the lowest speed component on it.
Pardon my poor English!!!!
Good luck!!!
Jan 19, 2009 | Magix Music Studio 2005 Deluxe for PC
Audio works fine but voice doesn't
You need to reinstall driver of your sound and installed properly
Sep 22, 2008 | Dell Inspiron 6400 Notebook
Won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Sep 01, 2008 | Philips SpeechMike Pro 5274 Handheld Voice...
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Playback is faster than recorded
close that windows
now click on it again (left click) and choose mixer
Does your mic show up there ?
Jan 11, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
David Payne
David Payne
