Question about Orion Cobalt Series CO154S Car Subwoofer
I'm trying to find out how big the box has to be for my two Orion Cobalt C0154S subs and if they should be ported or sealed for the trunk of my 91 Acura integra trunk
How much air space from 12 orion cobalt series 1600w dvc
box size? look it up on google in the specs or manual for your sub. it should say whats it is. bigger is better unless you have a sealed box or rubber surround
Apr 07, 2015 | Orion Car Audio & Video
Hi there, i have a orion cobalt 2105xp 400. i have hooked all up, but very little bass. i have 1 10" boston acoustic sub. i noticed that the led is constant red, is it supposed to be green, crossover...
amp is in protect mode. check your wiring and make sure your sub is wired properly for ohms. dual 4 ohm in parallel = 2ohm. dual 4 in series is 8 ohms. dual 2 ohm parallel= 0.5 ohms and in series 4 ohms. check ground and power wires. make sure sub isnt blown. a blown sub WILL cause this on any amp.
Sep 10, 2011 | Orion Cobalt 2105 XP Car Audio Amplifier
Trying to put ported reccomended subs in sealed box.
Well, 1.6 cubic foot for a 15 is not nearly enough. A ported box for 1 15 should be in atleast 3 cubes by itself. I suggest building a new box yourself or getting someone else to do it for you. If factory specs on those subs is no larger than 3 cubes per sub then I'd get the box built to 3 cubes per sub after all displacement and tune it in the upper 30's range. Putting big subs like that in a small sealed enclosure can and will damage a sub. and if you try to port an enclosure that is too small to begin with that will also hurt the woofer. Do it right or learn the hard way.
May 26, 2010 | Kole audio KMX-15 Car Subwoofer
My subs will not hit when my trunk is closed
just like a speaker system they don't work in a closed box it has to be vented, and you trunk is too well sealed you need to incorporate ports
May 11, 2010 | Car Audio & Video
I need to build a box for 2 AudioBahn AW1505Q subs need the specs on how big the box needs to be
try a electronics store like jaycar? they have the specs for sealed and ported speaker boxes depending on size and watts
Jul 28, 2009 | Car Audio & Video
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
Custom install of pyle red label sub
Start here: http://www.fiberglassforums.com.
Go to the "How to Make a Sub Box Mold Thread" and look over some of the photos.
Building a trunk box for a single sub is a great first project and depending on the time and attention to detail that you put into it, the results can be really fantastic.
Also take a look at the "Tools of the trade" thread. There's tons of good information and ideas on the fiberglass forum, including sources for materials step-by-step photo logs of various projects.
Hope this helps and that you enjoy your new DIY sub enclosure.
Good Luck!
Mar 24, 2009 | Pyle Red Label 12" Square Subwoofer Car...
Orion hcca 15.4 two woofers two d5ooo orion amps
if you want a nice thump or sound i suggest face them towards the back of the car that way the vibrations bounce off your trunk and hit you hard
thats how i have my 2 clarion 600's and thats the only way the pound good and they sound the best facing the trunk
Jan 10, 2009 | Orion HCCA-D5000 Car Audio Amplifier
12W3V2-D4 ENCLOSURE
12W3v2-D4 sealed or ported enclosure use.
Sealed 1.25 ft3 23" x 14" x 10"
Ported 1.75 ft3 29" x 14" x 12.25" - Slot port size 1.375" x 12.5" x 23.75"
12W3v2-D4
Fc: 47.4 Hz F3: 41.3 Hz Qtc: 0.83 Recommended Port Tuning: 30.3 Hz
Maximum wattage: 600 watts per driver.
I hope this helps you, more info can be found at: http://mobile.jlaudio.com/pdfs/12W3v2_MAN.pdf
Jun 24, 2008 | Jl Audio 12W3 Car Subwoofer
Orion Cobalt Series CO154S Car Subwoofer Logo
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
