Question about Zanussi F1245W Front Load Washer
Zanussi F1245W Will not spin! Works fine otherwise! Pump and Carbon Brushes OK!
  • 311 Answers
SOURCE: I have a Maytag MAV6300AWW,
The plastic pulley is worn out typically at the bottom- most common issue. It needs to be replaced. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 44 Answers
SOURCE: How do I access the drain hose to disconnect and
Hi
you need to remove back panel and tip machine back 45 deg from there you can get to the drain hose and change it.
regards
Posted on Mar 21, 2009
  • 95 Answers
SOURCE: zanussi washer washers,drians but will not spin
The transmission is belt driven so carbon brushes cannot be the issue. most likely it is a slipping or loose belt remove lower rear panel and check belt tension also check condition of the belt. In order to shift into spin there is a solonoid that activates the transmission you should be able to hear it click. if it just hums it may need replacment.
Posted on May 15, 2009
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
Zanussi aquacycle1200 F1245W When cycle advances-gets hung up on spin.
Hay Jim , sound like you need to replace ccu (main control board )good luck ,APPLIANCES R EN
Feb 26, 2013 | Zanussi F1245W Front Load Washer
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
The machine will not spin and there does not appear to be enough water in the drum when washing
This is a common problem and while it can be caused by a variety of malfunctions the most typical cause is a damaged lid switch. Look for a plastic pin attached to the bottom of the lid near the front opposite the hinges. The pin aligns with an opening in the top rim around the tub, this is where the switch is located. You can attempt to manually actuate the switch by inserting something (preferably non-conductive) like a plastic pen into the opening. This most likely will not work because the switch is probably physically damaged. To repair/replace the switch on most machines the chassis has to be removed for access.
Mar 18, 2011 | Zanussi F1245W Front Load Washer
Zanussi Aquacycle 1200 Model F1245W wont drain. I cleaned filter. Removed pump and tested if off line and it spins so I am presuming that the pump is not getting power. Is this a PCB/Timer Main Board...
We cannot say if the timer is problem without inspecting the wiring to the pump.
Consider an power supply wire to the pump is broken , then even if the timer is good it wont get power.
Sep 05, 2010 | Zanussi F1245W Front Load Washer
M/c won't spin
Take off top and rear half of machine cover
remove belt and spin drum by hand, (does it spin freely?)
make sure pump and drain hose are ok (clear)
there is a plastic ball (about egg size) in hose from drum to pump.
check motor brushes are at least 3cm long
if you have checked all these but the fault persists email me on andynj42@yahoo.com
Feb 09, 2010 | Zanussi F1245W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Spinning
check the motor for carbon brushes u will need to get inside undue the lid under the lid take off 2screws from each side the 1s nearer to the back undue the 2 at on the back panel at the bottom now there is ascrew on each side in the middle bottom hinded behind a plastic cover put a small screwdriver on nail through the hole in the middle pull to the side the plastic cover will pop out now now u can see the screw pull back panel out off the way to get into the washer there u will see the motor there should be a carbon brush on each side of the motor held in by 2screws these will be too low replace with new 1s m8
Jun 18, 2008 | Zanussi F1245W Front Load Washer
Zanussi 1245w fails to spin
suspect it may not be rotating on wash either. check the moor brushes
Mar 30, 2007 | Zanussi F1245W Front Load Washer
Zanussi F1245W Front Load Washer Logo
67 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
