Orage light winks 7 times then green; not printing
  • David Dally Apr 11, 2011
    first solution ineffective
  • David Dally Apr 12, 2011
    canon s520
  • 2,574 Answers
Which printer model do you have/?
Posted on Apr 11, 2011
  • Reparatii PC - Service IT
    This is a print head error .
    Try to reseat the print head.->
    Confirm that the printer is powered on.
    Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
    Hold and slowly move the print head lock lever up and down several times.
    Lower the print head lock lever to secure the print head.Holding the print head may cause it to not be seated properly. Perform this step using only the print head lock lever.Close the front cover.
    If the problem persists ,then the print head may need replacing.If your printer is still under waranty you may resolve the issue by taking your printer to an Authorized Service Facility.If your printer is no longer under warranty you may purchase a print head.->part number (QY6-0034-010)
    Brigadier General:
  • 3,917 Answers
Hi
If its blinking 7 times then the waste tank is full. Follow the bellow steps for the reset procedure.
Steps 1: Enter to Service mode
Unplug power cable and USB cable.
Open front case of printer and then press and hold power button.
Connected cable power to electric source then close printer cover and then release power button.
Tide USB cable to computer.
Steps 2: Reset Waste Ink Counter
Also check these steps. When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
If the aforesaid method does not work then you have a defective printhead.You need to replace your printhead.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
I have an oki 800 and the green is printing blue and orage as red. Can you help me please.
You either have contaminated developer powder BAD or need to change all 3 colors usually not black, and Developer powders (wor$e) or change your CYAN, YELLOW, MAGENTA toners.( the 3 super secret colors that make up our norm red green blue SSSHHHH don't tell anyone one...even if it's me)
Nov 08, 2014 | Office Equipment & Supplies
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
Mp220 absorber full check printer 5b00
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times
or more
Return to the menu selection
Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
No sound at all when start up orage mute light
Try to follow the following steps;
1. Start, then Run, then enter REGEDIT to open the Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the UpperFilters entry
5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the LowerFilters entry
7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 09, 2009 | Compaq Audio card Sound Card
Canon S630 Printer. Yellow light blinks 7 times, green once.
7 Blinks says that your printhead has gone out. Just needs a new printhead, QY6-0034-000. around $40.00
Aug 08, 2009 | Brother HL-2040 Laser Printer
Canon i950 won't print
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving
now is the most crucial information that has to be followed
Thanks And Regards
May 12, 2009 | Canon i950 InkJet Photo Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Orange light blinks 7 times then green light once and repeats,
It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
YBC (/\)
Oct 07, 2008 | Canon i950 InkJet Photo Printer
20 people viewed this question
k24674
