Question about Intex Easy Set Pool 15x36
I have a leaking valve on my intex pool. How can i replace or fix it without losing alot of water
5 Suggested Answers
  • 76 Answers
SOURCE: I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Posted on Jul 15, 2009
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
  • 8 Answers
SOURCE: New Intex FP621 4000 Pool Pump Noisy
You are right, this pump is just too aggressive for the inlet valve. It started in my second year, but completely failed the system in the 3rd year. Lots of noise as air was sucked in the inlet valve. The biggest problem this caused me, beyond airlocks, was my saltwater system was coding that it had a problem with the plates. There was no scaling on the plates as is usually found. upon bypassing the valve the problem went away and the whole system ran smooth and quietly. I wish Intex would upgrade this part to remedy the problem.
Posted on Jun 16, 2010
  • 8404 Answers
SOURCE: it says low flow, how can i fix it
Low flow means there is insufficient water traveling through the cell to make CL. Is your cell clean and clear? Is your filter clean and clear? Clean your cell according to the manufacturers instruction and back wash your filter.
Posted on Jul 24, 2010
Can I fix my input valve, on my sand filter, while water is in the pool?
IF YOUR ASKING IF YOU CAN REPLACE THE MULTIPORT VALVE ON TOP OF SAND FILTER HOUSING WITH WATER STILL IN POOL , SURE ITS POSSIBLE . 1ST UNPLUG PUMP POWER !!!! SECOND USING A COUPLE OF TRASH BAGS ADD ENOUGH AIR INSIDE OF THEM TO FIT JUST TIGHT ENOUGH DOWN INTO SKIMMER ON SIDE (ME I USE A OLD POOL TOY) WEIGHT OF WATER WILL HOLD THEM IN THERE , NOW YOU CAN DISSCONNECT YOUR HOSES , A SLIGHT TRICKLE MAY COME OUT (EASY TO REPLACE LOST WATER VOLUME) REPLACE THE VALVE , WAIT FOR GLUE TO COMPLETLY DRY (IF USED) THEN RECONNECT HOSES , REMOVE TRASH BAGS FROM SKIMMER(LET AIR OUT) , RECONNECT PUMP AND TEST FOR LEAKS
Jun 05, 2015 | INTEX Sand Filter Pump
We bought an intex sand filter last week and it runs strong for a little whole and the loses suction why is a this happening?
needs to be backwashed small filters dont have alot of filtering capacity keep backwashing until what is in your water is gone also super shock pool
Jul 04, 2014 | Pool & Spa
Repair multiple leaks in INTEX Pool bottom
need more info are you able to drain pool? if so coat with water sealant paint
Feb 15, 2014 | Intex Pool & Spa
Goodday i have a intex pool notice water missing over a course of a week think it is a very small hole as big as a pin how can i find the hole please help
If the hole is in the bottom of the pool it will be extremely difficult to find. I assume you have looked around all the sides for wet spots already. How much water are you losing? Are you sure it is the pool leaking and not the pump or filter? Look everywhere!
Nov 05, 2013 | Intex Pool & Spa
May 20, 2010 | Intex Easy Set Pool 15x36
I had boughten a intex pool from a garage sale and the pool is fine but the filter is leaking water everywhere and all the water that is in the pool keeps coming out.
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at intex.com
call them up and order your parts
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex Easy Set Pool 15x36 Logo
886 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
