Question about Nikon Cameras
My nikon isnt accepting the card i put in it to take pictues, but it is in. What do i do?
Has this card ever worked? Try a new one. I always keep an extra card near by.
Posted on Aug 07, 2008
SOURCE:
My nikon coolpix 33 will not accept memory cards , no matter which one I use, even ones that I have used in this camera previous. It says"out of memory" What is wrong?
Put an OLD card it and GO to TOOL menu and then FORMAT the card. if it cannot Format try another card. If it fails more than a few times the camera 'may' have problems.
Mar 07, 2018 | Nikon Cameras
My nikon d300 will not format the SD card....
Hi, Dear
Nikon D300 does not use SD card! It use CF card.
But if you have format problem in camera then I recommend format from a computer using memory card reader. And then put the memory card into camera and try to format! Here it does not, then you should show to your local repair shop and it will cost between $120 to $265 usually. In minor problem case it will be replacement of memory card acceptance unit replacement. But the problem come from main pcb then the estimate will be totally different!
Hope You Luck! A Professional Camera Clinic Guy
Apr 05, 2015 | Nikon Cameras
When i put hd video onto my computer from my nikon coolpix p100 camer the audio is fine but the video is choppy
first of all take a look at the sd card/ multimedia card you are using.. is it a high speed card? if it isnt then the problem is that the card cant keep up with the data transfer i hope this helps
Feb 07, 2011 | Nikon COOLPIX P100 Digital Camera
I recently put my memory card into the pc to copy all photos on to pc. now i canot take a pictue due to the camera saying this memory card is write protected help what do i do
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 23, 2010 | Nikon COOLPIX S200 Digital Camera
D300 cards not accepted chr message
try the last card you had in it before this problem occurred sometime the processor in the camera doesn't realize the disk is gone sort of like your computer once it starts reading a disk and you remove it half way threw the load. Well usually before yu can go any further on the computer you must put the **** back in and close the program out. This issue is usually case on cameras when the disk is removed before the camera is turned off.
Oct 08, 2009 | Nikon D300 Body Only Digital Camera
Will not accept a SD Card now.
first are you still under warranty, if you are don t tell nikon it was dropped they may not cover it if it was dropped. Tell them it stopped reading cards all of a sudden. See if they can fix. If warranty is up may need to get it repaired yourself.i had similar problem with other name brand camera. i didnt fix though was inexpensive camera. I know nikons are high in price so you may want to get fixed.
Aug 12, 2009 | Nikon D40x Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Dec 20, 2008 | Nikon COOLPIX P4 Digital Camera
How to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
4bfc547.jpg.
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Lexar card
Format the card in the camera and start over
Sep 04, 2007 | Nikon COOLPIX L4 Digital Camera
Cameras Logo
15 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
