Question about LG WM-2077C Front Load Washer
LG WM2016CW front load washer
Water sometimes does not enter machine; also, machine "hangs up" during cycle and will not finish
  • 489 Answers
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Posted on Sep 29, 2008
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM-2077C Front Load Washer Logo
237 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
