Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can i use any 2 stroke oil in my husqvana - Husqvarna "Chain Saw - 16" Bar, 3 Hp
  • 2,510 Answers
Yes, as long as it is a good quality oil. Some manufacturers recommend less oil in the fuel if you use their brand of oil, but using a branded make will not be detrimental unless it is a cheap make. Just watch te amount of smoke coming from the exhaust, it should not be excessive but should also just be visible in the sunlight.
Posted on Apr 11, 2011
Testimonial: "very helpfull thank you"
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
Brught a Kaweasaki HE130A edger. Seller told me that it was two stroke. Looking at it appears to be 4 stroke. Tank filler cap says gasoline only. Is it 2 or 4 Stroke? Regards Kevin
Gasoline only usually means 4 stroke.
2 stroke requires a mixture of gasoline and 2 stroke oil'
Look for an oil filler cap on the equipment, no oil filler cap means 2 stroke.
If you have an oil filler cap there will be a dipstick therefore your kit will be 4 stroke.
Hope this helps'
Chris.
May 11, 2011 | Garden
I have got 26cc homelite hedge trimmer what type of 2 stroke oil do i need for it, MANY THANKS
You can use any brand of two stroke oil as long as it says on the container that it is suitable for air cooled engines and you need to mix it at a ratio of 25 to 1. Regards Phil
Apr 19, 2011 | Homelite Garden
Which oil do you use for the ake 40 bosch chainsaw
You might miss someone answering your query as it is posted on the washing machine list!
I would re-post on the garden area.
Also state which oil you require- for the chain itself or to mix for a 2 stroke engine.
(actually for my Husqvana I use any of the 'normal' 2 stroke oils and any chain oil- very thick stuff!).
Cheers,
John C
Jan 30, 2011 | Washing Machines
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
1994 300 4x4 2 stroke, where do you fill the
2-stroke gasoline engines don't use a reserve of oil in the crankcase the way 4-stroke engines do. Instead, you add oil to the gasoline to ensure lubrication of the engine. The correct ratio to mix would be in the owner's manual.
Jun 04, 2010 | Polaris ATV
Husqvana 65 chain saw will rev fully when idle but dies when introduced to timber
Sounds like the saw is running lean. Check the fuel filter, air cleaner and muffler for plugging. Check the condition of the fuel lines and that the fasteners on the carburetor are tight. If all ok, turn the 'L' and 'H' jet needles on the carburetor CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and the engine should start and run. Allow the engine to warm up, pull the throttle full on, and adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet will allow it to 'follow the throttle'. Set the idle speed screw til the chain stops moving, but keeps the engine running. Hope this helps!
May 12, 2010 | Garden
Want to no if it takes petrol on its own when fueling or 2 stroke oil added to it aswell
i guess your asking if its a 2 stroke or a 4 stroke right ?
2 stroke engines dont have an oil filler cap , just a fuel filling point, the fuel used in a 2 stroke is just normal unleaded (aus) but you mix 2 stroke oil in the fuel before filling (about 50/1) or whatever it recomends.
4 stroke uses the same fuel but you dont mix the oil with the fuel , it has its own filler point for oil , however you must use a 4 stroke oil with these .
hope this is what you were after.
May 01, 2009 | Garden
Husqvana electric chainsaw
Hi.
maybe its not sharper enough to cut those things that u r trying to cut.
check the saw tooth and use the chainsaw sharpener if u don't know how to make ur chainsaw sharpener take a look on this link.
click here.
i will fix u but you should rate me deal??
Aug 18, 2008 | Electrical Supplies
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
90 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
