I have a small time internet cafe with 8 units. i am using manual in timing my costumers. i want to learn how to install a timer in my computer with free.
    Master:
  • 149 Answers
A small utility that will count the time used for tasks
The Timer application was designed to be a small utility that will count the time used for tasks. It provides abilities to create different timers, describe them, run and pause them and finally delete them trough a simple interface. Hope it will be useful.
http://www.softpedia.com/dyn-postdownload.php?p=123948&t=4&i=1
Posted on Apr 11, 2011
Cafe world in facebook freezes up my computer. Have to keep getting recover webpage message
have you tried using a different compatible browser type that can play cafe world aswell.. try downloading Firefox a free browser that is compatible with alot of web elements, and games.. you could also try Google chrome another good free web browser... but if you really want to stick with internet explorer 8 try erasing your cookies and maybe uninstalling and re-installing the browser.. if that doesn't work than try installing an earlier more compatible version of the browser.. hope this helps -CA
Jun 15, 2011 | Microsoft Internet Explorer 8
How to download and install internet cafe timer i have 6 unit and 1 server pls help me sir and ma'am.
Hello! try to find in google.com you need computer technician for that business, the requirement for your unit must be complete set., Prepare for ur needs : * router * RJ45 * UTP Cable * Internet Connection he need to make an IP AD each unit..
May 30, 2011 | Computers & Internet
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
I have A Time All Model TB 211 and need to learn how to set the time with the pins. Have no manual. Using for my Xmas lites, on and off. Outdoor use.
There are two 2 basic types for mechanical timers: Pins and segments
geno_3245_149.jpgTimer pins flip in and out using fingernail.
geno_3245_150.jpg Timer segments lift up using small tool or fingernail
geno_3245_151.jpg Sometimes segments pull outward away from center
To check timer functions after setting pins or segments, manually rotate dial to and watch lights turn on and off.
Dec 07, 2010 | RTO Intermatic #HB51RC Photo On/Off Out...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Computer hang-up when idle and while on handycafe mode
First, the supplier didn't need to replace the expensive motherboard. They likely did this because the graphics card was built into the motherboard. Rather than installing a video card into its own PCI slot, they got more money out of you by replacing the motherboard with another that had the graphics card built in.
This sounds like a processor issue. Try lowering the screen resolution. Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 15, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
Where can i find softwares for the server of my internet cafe?
hmmm. you need an Internet connection,, then 1 D link router.. 1 (16 port) D link switch.. 12 Internet cable or LAN cable for your server and workstation then try to search or download (handycafe for your server and workstation. i hope this cn be help.. ^^
Feb 08, 2009 | Intel Motherboard
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Feb 03, 2009 | Learning Resources Time Tracker Visual...
Networking
You mentioned that you wanted to install 8 units in an Internet Cafe. First thing is that you would need an internet connection after that you will need a router.
You will be connecting the 8 computers to the router and in turn to the internet connection.
if you need further assistance please contact me
Sep 23, 2008 | Computers & Internet
Ahielyd@yahoocom
call tech suprt on software your using tell them nee dto recatve new pc upgraded the cpu ok they will hook ya up
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
