When statring my computer hp presario cq61 a message appeared "no bootable device found. then i made the hard disk check and it showed "no hard disk exists" What can i do?
  • 63 Answers
Here are a few possibilities:
1. A huge possibility is that your hard drive has failed. This usually happens to computers 4 years old or longer. Unfortunately, it would be pretty costly to recover any data on a failed hard drive. You will have to replace the old hard drive with a new, compatible hard drive and install a fresh operating system on it. To do this, you need to consult someone who is somewhat familiar with computer troubleshooting or visit a store such as BestBuy for help.
2. The hard drive's cable is loose or disconnected (This usually happens when the hard drive was recently tampered with)
Posted on Apr 11, 2011
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
Every time I turn on my computer the following message appears: "For PCIE Atheros Ethernet controller v1.0.0.5 Check cable connection ..! pxe-e63: error while initializing the NIC pxe-mof:...
It sounds like the hard disk is faulty, the machine is trying to boot via the network card as it cannot find a bootable disk. You could try removing the hard drive and reseating it but the disk could be dead.
Apr 04, 2011 | Acer Aspire One PC Notebook
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
Well, my computer doesn't start up and the screen says "Media test failure, check cable", "No bootable device -- insert boot disk and press any key". I don't know what the cable is and...
The uProcessor can't find a bootable device and presumes your hard drive is no longer plugged in. Standard error message.
Check your BIOS for the hard drive listing. If it is listed there is no problem with the cables.
You will need your restore disc to boot from and repair your boot sector on the drive.
Feb 21, 2011 | Acer Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Computer problem, help.
    This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
    Jul 01, 2008 | Sony VAIO FRV25 Notebook
    Computers & Internet Logo
    65 people viewed this question
    David Payne
    David Payne
