Question about Ryobi 12v Drill Driver Hp412 Free Tool Only
Bd 121 power screwdriver- battery and spare defunct - can they be revived? what is the cost of a replacement battery?
    Novelist:
  • 185 Answers
Have a look in your yellow pages under batteries. Ask the companies about replacing the batteries in your unit. This is generally half the cost of a new battery set.
Posted on Apr 12, 2011
Will not turn on
Double check power outlet and power cord. Remote batteries? Remote itself?
May 05, 2015 | Televison & Video
When I turn on the TV with remote, why does it make many attempts before lighting up the screen?
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 13, 2015 | Televison & Video
TV will not turn on manually or with the remote
Dec 08, 2014 | Vizio Televison & Video
Black and Decker rechargeable Screwdriver
There usually is an indicator on the charger that lights while charging is underway. However, the charger can light up and charge away merrily without reviving a dead battery.
Dec 01, 2013 | Electrical Supplies
How to take apart hp ze2000
Use a screwdriver. At the bottom there are a few doors, one for the ram, fan, battery, and Hard Drive, remember you do this at your own risk, and any screwups will result in your laptop being defunct
Nov 12, 2012 | HP Pavilion ze2000 Notebook
Have a vector model veco 10 BD jumper box. need battery replacement. where can I call and order?
The cost to ship lead-acid batteries is really cost-prohibitive. I suggest going to your local Batteries-Plus store for the replacement.
Nov 03, 2010 | Vector Electronics - Others
How do i refresh battery
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Dec 04, 2009 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
I have a dewalt de9116 charger and when a battery is put in it flashes constantly even a new battery. Is the charger defunct?
I would say tee charger is no good. The only internal component is a circuit board so it is not worth trying to repair it/get spares as it will cost the same as replacing the charger.
Nov 29, 2009 | Dewalt Drills
Intermatic Model DT 121 "LO" after programming
That is the visual indication for a "LO" battery. You need to replace the battery very soon or the timer will cease working properly.
Typically with this model of Intermatic timer, you only have about 30-40 seconds to change out the battery before the programming is erased and you'll have to re-enter your desired on/off cycles and such.
The battery is located under the manual push faceplate, just flip it down and you can either use a small flat bladed screwdriver or your fingernail to open up the battery compartment to change out the battery.
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | Hardware & Accessories
Dell 42" 1080i plasma issues after TV warms up
the power board needs to be inspected. you need a t20 torx bit, and phillips screwdriver. do not work on unit around carpet. stay away from carpet.you need a digital multimeter as well. remove back cover, and set meter to VDC. take black probe, and stick in one of the upper holes. look at the top right of the panel for a white sticker. this gives the proper voltage readings. on the power board, located middle top (big bd) look for the vs, vset, va, vsc settings on pow bd with red probe, test each one for proper voltage if 2 or more mismatches, the power bd needs replaced. do a ebay search for bd id number located on bd or simply type dell 4201 power bd.
Jan 23, 2008 | Dell W4201C 42 in. Plasma HDTV
Ryobi 12v Drill Driver Hp412 Free Tool Only Logo
166 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
