Question about ASUS K8V-MX Motherboard
No lan - ASUS K8V-MX Motherboard
    Master:
  • 149 Answers
Download the drivers onto a CD via an Internet-accessible computer: http://support.asus.com/Download.aspx?SLanguage=en&m=K8V-MX&p=1&s=20.
Ensure that the the device is enabled & that the network device (modem/router/etc.) is powered on & functioning.
Reseat the Ethernet cable on both ends.
Try using a different cable.
Reboot the network device & the computer.
Look for activity lights at the LAN port once connected to the running network device.
Inspect for 127.0.0.1 or any other listing in the proxy server settings:
Select "Run" from the Windows™/Start menu, type "inetcpl.cpl", press [Enter], go to the "Connections" tab, & click on "LAN settings". If nothing there has been selected, then it is not the problem.
If this is a new problem on an older machine, then it could result from a firewall setting or from malware or a virus.
If all else fails, try installing a NIC (network interface card) in order to get around the non-functioning component.
Posted on Apr 11, 2011
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
Uninstalled lan drivers
u can remove your lan card drive from add remove option in control panal
if u have lan card problem open your cpu diconnect lan card and clear its golden connector and clean pci slot which in on mother board then again plug it and reinstall lan drivers if problem not fix try with replace new lan card 100 percent it will help u
Feb 04, 2011 | Computers & Internet
Lan card send reciving problem solutions
The lan card send receive problem occurs only due to following reasons
1.The network cable connection not having good connectivity
2.Due to physical damage of lan card due to power and etc
3.Due to improper fixing of lan card in case where lan card is not inbuild
solutions
you can check which is the problem
if the lan card is damanged means replace with external card
Feb 13, 2010 | Computers & Internet
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Dax router
The 2 wire Home Portal 100w is a Modem/Router combination with wireless. But it has only one LAN port. So I understand that you are trying to use a DAX router for extending the number or ports. The reason they may not communicate if 2wire LAN is connected to DAX WAN is both may have same IP address. If the router has similar IP on WAN and LAN, it will not communicate. For that changing DAX router's LAN IP will be a solution or you can do LAN to LAN cascading. Connect 2Wire LAN to DAX LAN and dont use the WAN port. This way you dont have to change anything in the configuration
Dec 04, 2008 | 2wire HomePortal 100W (1000-400026-000)...
ASUS K8V-MX Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
