The tray for the dvd player does not open. Also, cannot change on button to standby/on.
  • great-Gma Aug 07, 2008
    This is model DVP 1013.
    Scholar:
  • 137 Answers
It sounds like a power issue. Please unplug the player, wait one minute and then plug it back in. If the player does not respond then check the power connections - make sure the powere cord is properly installed and pluged into a live outlet.
If this does not clear up the problem please post details of the manufacturer and model number, as well as information on any lights of other indications on the unit when the power button is pressed.
Regards,
Bob Headrick
Posted on Aug 07, 2008
  • 6,487 Answers
Try first turning the unit off for 5 minutes and turn if back on and see if you can now open the dvd tray..
Good luck.......
  • 3,037 Answers
Lets try to diagnose the first problem first. Usually there is a small pin hole on the front of the dvd player to eject it. If you can't find one, the next easiest option is to unplug it and plug it back in and then trying to eject it. If that doesn't work, then the motor to eject it or some other wire may have broken or become loose. You will need to unplug the unit and then start taking off the outer panel to get to the motor and dvd. It is pretty basic, phillips screws on the outside and basically everywhere holding everything together. Check the operation of the motor and whether a belt came off track or if a gear is out of alignment. If everything looks fine, check for power on the motor wires with a meter while trying to eject the disc. If there is power, replace the motor with a new one from an electronics store such as Radio Shack. If there is no power, trace the wires back until you find the problem basically. I'd bet it is the motor though. let me know if you have any questions or need any more help.
my best to you
SOURCE:
Unit on standby mode only, the dvd rack didnt open when open button was pressed.
Turn off and unplug at mains Plug back in and turn on press standby button so power light come son. If pressing open button on player (rather than remote) doesn't work it may be a disk that is not sitting properly in the tray. You could try sliding a very thin blade (preferably something with an insulated handle!) gently in the top of the tray to press the disk downwards whilst gently prising under front edge of the tray with a small screwdriver. If you can manage to press the open button at the same time as doing both these things it may help.
If that fails to solve the problem it may be a broken drive belt or worn cogs in the tray operating mechanism. DVD players are so cheap these days that repair is seldom worth the expense.
Feb 23, 2011 | Philips DVP642 DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
Durabrand LEDVD0701 dvd player
Taken from another site in case you still need to unlock it.
The Pacific hack works for this one!
Multi-Region Hacks for Pacific DVD-1001
Oct 20, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Ekse
